Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How To Remove Sprinkler Water Spots
How To Remove Sprinkler Water Spots using The Least Aggressive Method Approach
This is a nasty problem that usually happens after you've just washed and waxed your favorite ride... and unaware you've parked next to a sprinkler. Then when you return to your car....
Sprinkler Water Spots!
Luckily they're only on half the car...
The question is, are they Type I or Type II Water Spots? Let's hope they're Type I and will wipe-off or wash off, if they're Type II Water Spots we'll have to use some type of abrasive compound or polish to level the paint surface in order to remove the spots.
We've pulled the Mercedes-Benz into our studio where we can work out of direct sunlight on a cool surface.
The terms Hard Water or Hard Water Spots are commonly used to describe these types of spots on the surface of the paint. What's actually making up the spots are minerals and other substances dissolved in the water. After the water evaporates off the paint, the minerals, (the components referred to with the word hard in the terms Hard Water or Hard Water Spots), remain behind.
Our hope is that these spots are simply a topical defect and not a sub-surface or below surface defect. You will find out by simply washing and drying the car or wiping the panels clean using a clean, soft microfiber towel.
When following the approach of using the least aggressive product to get the job done, the first thing you want to do is to see if you can either wipe the sprinkler water spots off or wash the sprinkler water spots off. Since this car was recently washed and waxed and it's kept inside a garage when not being driven, we're going to try to wipe them off using a spray detailer with a clean, plush microfiber towel.
When removing fresh water spots, use your spray detailer heavy, or wet. Using a product heavy or wet means using extra product, more than you might normally use. The reason for his is you want lots of lubrication on the surface to help prevent any potential scratching or marring of the finish as you're wiping.
Remember, always fold your microfiber towels 4 ways to give you 8 wiping sides with plenty of cushion to spread out the pressure from your hand and wipe the paint gently.
Start out by spreading the spray detailer around to one section and then flip or fold your microfiber towel to a fresh or clean portion to remove the residue and buff to a dry, high shine.
Luck is with us... the paint is safe as the Sprinkler Water Spots did not etching into the paint and using plenty of spray detailer and a clean plush microfiber towel left a scratch-free finish.
