How to Remove Staining in Original Single Stage Lacquer Paint-HELP!
Rich Thompson
Hi folks. I am working on my all original 1966 Chevrolet Corvair Monza with its original single stage, lacquer paint.
The color is called Danube Blue. It is a very dark blue with small metallic flake (can almost look black in certain light). I have been using Mike Phillips method of the Meguiars #7 multiple soaking method in stages with a terry cloth towel. It has brought back a lot of depth and shine to the paint and even helped some areas that were a little crazed as well.
My issue is this: there are some spots on the car which have some what i think is staining. Areas where something has dropped onto the paint in its life that have left lighter stained spots and/or streaks. It doesn't look like brake fluid or anything of that nature; just something that was on the paint (maybe acid rain, tree sap, soda, etc.?) and lightened the spot on which it sat.
The #7, which improves the look of those spots a bit, does not make them really go away. Souveran wax helps to hide them a little, but not much.
Being careful not to remove too much paint, is there any ideas that some one may have out there to help remove or greatly improve the areas that have these stains?
I realize I may need to be stuck with these, yet someone out there may have some ideas or methods out there that I may not be aware of of removing/improving them.
Help!
Thanks,
Rich
By your description I'd say there's nothing you can do beyond what you've already done.
In the past I've used "oily" protectants to saturate and brighten old single stage lacquer. You might try that, although the principle behind this is similar to what you've already done with the Meguiar's 7.
You just need to have realistic expectations in your case... It's unreasonable to expect perfection.
I agree with this.
Outside of abrading the pant to your sense of risk, treating with the #7 and then the Pinnacle Wax, (good choice by the way for this type of paint after #7), you've done all you can do.
More abrading, i.e. compounding or polishing may remove more staining but as you already know, sooner or later you're going to see PRIMER and the risk in my opinion would not be worth it.
It's better to accept the staining as the natural patina for a car and car paint that is 54 years old.
Does the staining look like this?
From my article,
3 - Types of Water Spots - Type I, Type II and Type III
Scroll down past Type I and Type II info
Type III Water Spots
Type III Water Spots are spots that look faded or dull and are found primarily found on single stage paints after a water source lands on and then pools on the paint and is usually left to dwell on the surface for some measure of time before it evaporates or is wiped-off the surface.
Modern clear coat paints tend to be harder and impermeable, that is non-porous, so liquids don't penetrated easily and thus stain spots tend to be topical, that is only affect the very upper surface and are easier and safer to remove with a compound or polish.
Older single stage paints tend to be soft and permeable, or porous, it's common for liquids to penetrate into the paint and stain the paint below the surface. Removing stains out of single stage paints can be risky because in order to remove the stains you have to abrade the paint and if the stains penetrated deep then you risk removing too much in an effort to try to remove them completely.
Yes, Mike, the picture you provided has some similarities to the stains on my paint. Not grouped together like this, but they are a bit more isolated. In the spots I have, they have lightened the color of the paint in shape of whatever liquid had rested on the paint.
Thanks for sending me this! And for the compliment on my Corvair, Mike. It is a rare color to begin with and am very lucky to find one with its original paint :)
Rich
Hi Mike,
Yes, these look similar to spots on my paint, yet they are larger and more scattered/less numerous on the rear deck lid and roof. They have taken the shape of when whatever liquid had fallen on the car and left that spot behind.
In dragging my fingernail across them, some (not all of them, mind you) feel a little rough (possibly checking?).
I decided to add extra #7 on top of those spots in the meantime for daily soaks to see if that would add to the improvement.
Thanks for the complimen on teh car, by the way. Very lucky to have this rare color in an original paint car...only 27 K miles as well.
Rich
Hi Mike,
Rich
This is a common problem for older single stage paints and sorry to say there's simply not much you can do.
In fact - I would say the only thing you can do is the #7 Rub Down.
Thanks Mike. I had ordered some more Souveran early this week from your site, so i will be eager to get some on the car once I through with my multiple soaks with #7.
I think if I can just soak them as much I can, I can take some of the curse off those spots.
Thanks again, Mike!
Rich
OK Mike. I will work on that this weekend and see what I can get for you!
Thanks!
Rich
Hi Mike and to the Group,
Just following up on your last piece of advice. I have done a week long, multiple soak of #7 on my Corvair, and then followed up with the Pinnacle Souveran wax.
Very happy with the gloss, and I now can see clear and crisp reflections on the paint surface.
One question: I do have some slight scratches in the paint surface that you can see. The worst of them can be felt slightly be dragging a fingernail across them.
Some of the surfaces which have the scratches are still in good condition. While some are found on surfaces which have some light crazing in it, especially the rear deck lid where the engine is.
Is there a recommendation that you others here might have as to what could be used to remove or lessen some of these scratches? I realize due to paint thickness and or crazing, there might not be anything I can do....but maybe there is a product and method that might work?
Any ideas, folks?
Any ideas, folks?
Too risky in my opinion. Live with the scratches.
You can only have original paint once.
If you have intentions of restoring and repainting in the future then maybe it's worth the risk. If not, leave it alone.
My recommendations are based solely on your description. If I could see the defects first-hand, I might change my mind. Nevertheless, take one thing I said as gospel... You can only have original paint once... There's no going back.
