How to Remove These Dirt Spots?
spielwurfel
Hello guys!
So I have a hatchback and the back pirtion of the car gets dirty as hell. After doing a very good wash, using APC and claying, I still can see these very tiny dots of dirt that won't come out. I actually don't have much idea of where they came from, but they stand out on my white painting when I look closer. Any thoughts on this?
Thanks!
CarPro Iron X. Must have for such a problem. Tiny flakes of metal like rail dust on a new car become embedded in the paint.
That looks to be some sort of air contamination/fallout, use something like iron x then clay bar the area and shall get rid of those spots
Hello guys!
Thanks!
That is road contamination, like oil/tar, used to see it all time when I had a white Lexus. You can remove it by claying but you have to work it and keep the surface well lubricated. I found that nano skin on a 3" polisher/backing plate works really well. This is one of the main uses for my 3" Griot. If you are going to try a clay bar again, you will want an aggressive clay.
I see what I call rust blooms that shows up every spring after salt and slurry is put on the roads,as others have said iron x will get rid of most of it and then clay
Also looks like some tar you could spot treat with tarx.
Sent from my XT1585 using Tapatalk
Thanks guys, I'll go for the Iron X like solution. Can I clay while Iron X is doing it's work?
I think it might degrade the clay. Rinse well, then clay.
No ,I spray the iron x on a washed panel ,then come back with a 1/2 a grout sponge and work it around, wait a few minutes then rinse and rewash,all that will be left is the tar specks,hit them with some tar remover and a make-up pad ,then dry,then clay.
Make sure you apply in the shade so the iron x doesn't dry onto surfaces
