Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to restore the OEM paint on a 1967 Corvette?
Received the below via an e-mail. Going to answer here on the forum and Mr. Tomato will be joining in on the discussion.
Mike
Morning there Mike! First of all thanks for your article on the Lincoln Land Yacht. Most intriguing yet intuitive article to read regarding preserving and polishing very old paint. You have a certain way of getting your point across to even someone like me with severe ADD!!
Anyways I have a client with an all black '67 Vette with OEM paint non metallic.
The paint for the most part is in pretty good condition considering the age. However it is covered in swirls and few surface scratches from the guy who services his cars mechanically wise. Of course excellent on that aspect of things but clueless when it comes to washing cars!!
My approach is thorough wash (no rust anywhere, hard top non vinyl exterior), clay treatment then first give it a shot with white 5" Hexlogic pad, Sonax Perfect Finish via Griot's Garage DA with Megs MF System 5" backing plate.
From previous experience I do expect gloss galore but as for the cutting pretty sure it won't clean up the scratches or swirls 100%. If so my next step will be to hit the paint with Megs D300 and Megs MF 5" pad at 3.5-4.5 setting on my GG DA. This usually cleans up mostly anything I've thrown at it so far without any problems. Might do minimal wet sanding if needed and clean that up via Megs MF/D300 which works wonders on sanding marks.
My question to you is do you think the above will suffice to Safely correct this '67 OEM Vette paint? I don't own a rotary or any wool pads as my collection of Megs MF and various makes of foam pads have been able to give excellent results on the types of cars I work on which are usually much newer Euro toys. Any info on how to tackle this $250K toy would be greatly appreciated!!
From the DFW area
Mr. Tomato
:xyxthumbs:
Mike
From the DFW area
Mr. Tomato
:xyxthumbs:
