justin_murphy
- May 7, 2006
- 2,852
How-To:
Rotary or PC Cord Extension
Tools needed:
Rotary or PC
25 foot extension cord
3/8" Heat Shrink Tubing
(2)16-18AWG Crimp aka Butt Connectors
Crimpers
Wire Strippers
Heat Gun
(Hair Dryer will work but will take longer.)
The Process:
As I'm getting ready to really start learning my Chicago Tools rotary (awesome machine for 30.00!), I really didn't like the fact of a 5 foot cord. So, since it was raining today, off to Lowes I went to gather my supplies.
First, here's a look at the goods.
You want to cut off the male end of the rotary's cord and also cut off the female end of the extension cord. Then you want to expose about a 1/4 of an inch of the inside wiring of the white and black wires. Ignore the green wire on the extension cord.....this is for a ground and the rotary has a floating ground.
Next, just match up the colors and crimp away. Make sure you slide the heat shrink tubing over one of the cords first.
Slide the tubing over the crimped wires like this.
Break out the heat gun or hair dryer. Careful, this thing gets hot!
After heating (will not take long) the tubing constricts over the mended wires and crimps. This makes for a water tight seal too. The tension is also now exerted on the tubing and not the crimps if pulled upon.
All done! 30 feet of "non'cussin' if my cord come out" length!
Thanks to all!
justin30513
Tools needed:
Rotary or PC
Crimpers
Wire Strippers
Heat Gun
The Process:
Thanks to all!
justin30513
