How to shorten pressure washer gun???
BMGz33
I'm trying to delete the wand off the gun and just be able to connect a quick disconnect fitting to the tip of the gun to shorten it but I can't find the right fitting, any help is appreciated...
I have a craftsman pressure washer, I tried looking on amazon for the right fitting but I'm completely lost :confused:
Any help is appreciated, thank you :xyxthumbs:
Could you cut the barrel down to the desired length and rethread the end?
Should be able to find all the various fittings you need at Northern Tool. If nothing else.... you can get a new gun/wand and build it however you want. :)
