Evan.J
- Sep 18, 2012
- 4,915
I had received a PM from a forum member asking me how I apply Sonax Polymer Net Shield (SPNS) to the wheels. I figured perfect time for me to show how I apply SPNS to wheel and paint.
For those who haven't seen or read about SPNS here is the product description.
First lets start with how I apply for the vehicles paint. Always start with a washed and dried vehicle. If the paint is need of a decontamination with a clay bar or clay alternative then proceed to that first. Once you have the paint in the condition you want and are ready for your LSP time to bring out the SPNS.
Items required:
2 Soft Plush MF towels
1 Can of Sonax Polymer Net Shield
First spray a small amount of product directly on to the towel
Next spray a small amount of product to the panel. (I find that working in smaller sections makes the application of SPNS much easier. If you are working in warmer climates you maybe want to break down panels into 2-4 small sections)
Spread the product evenly over the working area
Once you have spread out the product you will see some hazing and or flashing
Take your clean MF towel and go over the area to remove any leftover product and reveal and beautiful shine.
How to apply Sonax Polymer Net Shield on wheels
The same procedure working for wheels as well
First spray a small amount of product directly on to the towel.
Next spray a small amount of product to the wheel.
Work the product over the entire surface of the wheel.
With a clean towel buff off the excess product
Once you have removed all the excess you are finished
Thanks for looking
rops:
Sonax Polymer Net Shield is a cutting-edge aerosol-based spray sealant that takes minutes to apply and lasts up to six months! Sonax Polymer Net Shield is formulated using advanced German technology to provide a level of paint protection that used to be exclusive to liquid paint sealants. Sonax Polymer Net Shield takes just minutes to apply and your paint will explode with color and depth like you’ve never seen before!
Sonax Polymer Net Shield is formulated using an organic and inorganic network of hybrid polymers. This new generation of polymers produces crisp, clear reflections while protecting paintwork from UV rays, acid rain, bird droppings, airborne contaminants and even road salt. The surface tension created by Sonax Polymer Net Shield causes water to bead up and roll off; your vehicle will stay cleaner in between washes because nothing will stick!
Sonax Polymer Net Shield is packaged in an aerosol can for two reasons: First, as soon as the contents are exposed to oxygen, the hybrid polymers immediately begin to cross-link and harden. Second, ease of application! Thanks to its aerosol packaging, Sonax Polymer Net Shield takes just minutes to apply. Simply spray Sonax Polymer Net Shield directly onto the surface or onto a foam applicator, spread evenly and buff off to reveal a reflective, glass-like shine.
Let your vehicle’s paintwork reap the benefits of German technology with Sonax Polymer Net Shield!
Items required:
Thanks for looking
