Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to start a new thread & How to reply to an existing thread
Everyone is "new" to a discussion forum at least once in their forum life. If you're new to discussion forums, here's a picture tutorial that will show you how to start a new thread.
If you have a question about detailing your car, then it's usually best to start your own dedicated thread than it is to do what we call, tagging on to someone else's thread.
Here's why you want to start your own thread...
By starting your own thread, your topic will get better and more attention which means you'll get the help you're looking for faster and more effectively. Starting your own thread helps you to help yourself.
Note that before you can start a thread or reply to an existing thread, you need to be a registered member of the Autogeek Discussion Forum.
After you have successfully registered with the forum and your account has been processed, you should see your forum nickname on the forum homepage on the right hand side in what's called the User CP block.
What you should see if you're logged in...
(The homepage of the forum is made up of "blocks" of information as a method of compartmentalizing specific types of information.)
If you don't see "Welcome back Your Forum Nickname" in the block that means you're not logged in and instead you will see a place to enter your forum nickname and your password.
What you will see if you're not logged in...
You must be logged into the forum in order to start a new thread or reply to an existing thread.
Click here to go to the forum homepage to see if you're logged in.
In the below post, I'll show you how to Start A New Thread
Click here to register
Click here to go to a picture tutorial on how to register - it's not hard but sometimes pictures can help
