How to stop windshield from fogging up every morning ?
Oz_TCH
Anything I can do to stop it from happening ?
Slightly leave window open ?
Any idea ? Any product to help stop it ?
I use the wiper blade and that clear it up but hate that it mess up my windshield. Can't have whole car looking good with dirty windshield.
Thx.
If you have air conditioner, use it full blast directed towards windshield (fresh, not recirculated air).
You do seem to have quite a quandary!
-Are no other vehicle surfaces being fogged/dewed upon?
-If not in too big of hurry...Blast away with the defroster.
(But then...there goes the plastic cowl getting water-spotted
from the dripping-wet wiper blade inserts)
-Park your vehicle with the business-end pointing East.
-Leave a little later in the morn.
:dunno:
Open both of the front doors, spread a beach towel across the windshield, tuck the ends of the beach towel into the vehicle, and close the doors to keep the towel in place. In the morning remove the towel and drive off. I see people use towels, cardboard, sheets, old shirts, etc.
The problem is too much moisture in the air in the cabin. Air con gives you dry air, so it helps absorb a bunch of that moisture. Open windows, don't use recirculated air.
P.S. you can use air con with the heating on high ;)
Thanks y'all. Dunno if it's fog or dew but its only on the outside.
May be I'll try Fog-X.
Sounds like you are living in the south with high temps and really high humidity. Depending on how thick if you can see well enough to drive safely, I find it clears at speeds above 50 without leaving any residue. But yeah, nothing worse than the morning after seeing all that heavy due clinging to your vehicle.
No electrons were harmed in the production of this post via Tapatalk
The quickest way to get rid of it is to heat the glass. Warm air can hold more water than cool air.
Rain X makes a product called FogX. Have not used it in years. I remember it being hard to keep from streaking.
