Thanks Mike for the tips. Took a white applicator and Scratch-X and the pad turned red...
We didn't do the entire car tonight, mainly because we wanted to do a section and check the results. This is because the car had been repainted at some point prior to his possession, and the paint job wasn't really great to begin with...
@Jaretr1, that is why I believed it wasn't clear coated. The paint didn't have luster or a glossy shine to begin with... some parts are thin, and there were a lot of scratches, some that probably just won't come out unless we compound or wet-sand... (which we did not do tonight).
I put down a coat of #7 on the hood & fender tops. I was going to leave it for 24 hours, but the owner of the car was hesitant so I respected that and wiped off the #7.
Used PC 7424 and Orange with Pinnacle Swirl & Scratch remover and did small sections with 6 sections passes each, then wiped them off.
Used the PC7424 and Pinnacle Polish, again using section passes over small sections.
I forgot my Pinnacle Souveran, so I had a bottle of Mothers Detailing spray and did a quick spray and wipe.
Before:
After:
