Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to Test for Single Stage or Clear Coat Paint
To test for a colored single stage paint, try to use a white polish and a white applicator or light colored applicator or cloth.
If you're testing white paint then try to use a polish with a color to it and a dark colored cloth. The reason for this is so you can confirm that you're removing white paint and not just seeing the color of the polish or the cloth.
If the cloth and polish are both white it will be hard to see paint pigment.
Use an ample amount for plenty of lubrication as you're going to want to push firmly if no oxidation is present as was the case with the finish on the classic car.
Confirmed, we're working on a single stage paint... also note the heavier accumulation were my fingers pressed down with the most pressure... this is because you can exert more pressure to the small area of your finger tips than you can with your entire hand, you can use this to work for you or cause problems depending upon what you're trying to do...
