How to truly remove odors?
YankeeFan
Just curious if I will need to go to a local detail shop for them to use an extractor or are there other options? Will an extractor even do the trick? I currently wipe down seats with Folex, spray with Valugard Odor eliminator and keep all 4 windows open while sitting in the garage. But once windows are closed there are odors, not smoking, not body odor, just an 8 year old car with odors.
Thanks,
Howard
Have you owned this car the whole time? Is it cloth upholstery? Is the odor related to use of the air conditioning?
Thanks,
Howard
You will need an enzyme that will kill the bacteria. There are many on the market.
My own opinion is that many people clean the seats and carpeting, but forget about the headliner. The headliner is a large surface capable of trapping a lot of odors. People think that cleaning the seats and carpets has failed. It hasn't failed, it's just that they have neglected to also clean the headliner.
i have used a product called BLAST before - it's a two part granule bottle that you mix in a bag and place in the car...almost like a bomb or fogger. supposed to be able to handle decomposing flesh, smoke, fish, etc.
i used it for smoke. but, i also used a green machine and enzymatic cleaning solution on all of the cloth (seats/headliner) and carpet first, just to be thorough.
it smells like chlorine at first but eventually goes away. just make sure you put it in a cardboard box, not directly on upholstery. and follow the directions. leave it in there for a day and stay out while it works.
honestly i don't even know if it's available any longer. but it worked. :shrugs:
Used car, past owner leased it for 2 yrs, dealership added a vanilla scent that finally dissipated. Yes cloth and no not due to the AC as I don't use it often and no additional odors when on
Interesting, I will try that. Thanks......
Biological products, as Rsurfer says, can do a good job. One thing to remember with this product class is that longer contact time is better - they are 'alive' so don't work as fast as chemicals. There are also chemical de-odourisers, which I actually are more effective but it is harder to identify them on the market - they get mixed into the 'odouriser' class (which do nothing more than add a strong - pleasant - odour).
After all the interior surfaces have all been cleaned by whatever is the correct method for that type of surface. And the A/C ducting has been cleaned of any mold or mildew, then it will be time for the Nuclear Option.
Treating with Ozone. I have used an ozone generator on a couple of cars that had been given up on by others. Vomit and dirty diapers in a car baking in the sun is pretty hard to eliminate the odor. But a six hour treatment (twice) with the ozone generator did it. And the odors did not come back.
