Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to use 303 Aerospace Protectant to Restore Vinyl Seats by Mike Phillips
303 Multi-Surface Cleaner & 303 Aerospace Protectant
What is it?
2-step system to clean and protect vinyl.
What does it do?
The vinyl cleaner safely lifts and removes built-up dirt in the weave of the vinyl and the protectant restores a rich vibrant appearance with protection.
When do I use it?
Anytime you need to clean and protect your car's vinyl interior or any vinyl surface in cars, boats, suvs, trucks, boats and even around the house.
Why should I use it?
To preserve your car's vinyl interior for both appearance reasons and resale reasons.
From the manufacturer
303 Multi-Surface Cleaner uses surfactant cleaning technology to lift the most stubborn outdoor stains from patio furniture and cushions. 303’s revolutionary cleaner is safe and effective on teak, resin, plastic, vinyl, stainless, and any water-safe surface. Preserve your outdoor investments with 303 Multi-Surface Cleaner.
Remarkably, 303 Multi-Surface Cleaner removes things like leaf stains, tree sap, wine, and oil without removing the color from dyed outdoor fabrics. Use it on patio cushions and umbrellas with confidence.
303 Multi-Surface Cleaner works equally well on teak, wicker, plastic, and stainless steel. Outdoor grilling stations complete with stainless steel cabinets are popular in many new homes – 303 Multi-Surface Cleaner makes it possible to keep stainless steel looking as good as the day it was installed.
303 Multi-Surface Cleaner, like all 303 cleaners, uses a blend of surfactants, sequester agents and hyper-wetting agents to clean surfaces. Surfactants surround and lift soil – even grease and oil – from any surface.
303 cleaners do not strip color or finishes, they are not acidic or alkaline, and they are environmentally friendly. 303 Multi-Surface Cleaner is nontoxic and biodegradable. Plus, 303’s cleaning ability is simply amazing!
Use 303 Multi-Surface Cleaner full strength or diluted. Warm water and mild agitation will enhance the cleaning ability. A green Tire & Wheel Brush will work to loosen stubborn grime and its feathered bristles are gentle on most surfaces. Stubborn spots will require some soaking time to get the best results.
Follow with 303 Patio Furniture Protectant on vinyl, fiberglass, resins, powder-coated stainless steel, and plastics. For textiles and fabrics, use 303 Aerospace Protectant.
303 Multi-Surface Cleaner removes stains that you never thought would come out: leaf stains, pine needle stains, barbecue smoke, and grease from food. You won’t be embarrassed by stained patio furniture again – clean it up with 303 Multi-Surface Cleaner.
Here are features of 303 Aerospace Protectant that will surely benefit your life:
Unbeatable UV protection. 303 Aerospace Protectant has a SPF of 40, the most UV protection offered by any surface protectant. It will prevent drying, cracking, and fading caused by overexposure to the sun. It was originally formulated for aerospace and aviation applications, machines that come much closer to the sun than your vehicle. 303 Aerospace Protectant is the single most effective protectant on the market.
Stain resistant. 303 Aerospace Protectant repels water and dirt, and resists stains. Treated surfaces require less cleaning and will remain in like-new condition. It restores the original finish to vinyl, rubber, plastic, acrylic, finished leather, and fiberglass. 303 is never oily or greasy.
Multipurpose. Use 303 Aerospace Protectant on vinyl convertible tops, vinyl seats, tonneau covers, car bras, vinyl awnings, dashboard, trim pieces, and all over your boat. It is safe on vinyl, rubber, plastic, acrylic, finished leather, and fiberglass. 303 Aerospace Protectant provides the best protection you can provide for a multitude of materials. Nothing works better on clear plastic to prevent yellowing, hardening, and clouding.
Most recommended by manufacturers. 303 Aerospace Protectant is recommended by name by more manufacturers of awnings, RVs, tonneau covers, vinyl convertible tops, and spa covers than any other protectant in the world.
My comments....
I've seen first hand the 303 Multi-Surface Cleaner remove stains that other products didn't touch. This product is GOOD. Take my word for it and get a bottle and thank me later. The 303 Aerospace Protectant is also one of my favorite products for protecting pretty much any kind and type of vinyl surface inside or outside.
Project car: 1967 Chevy Camaro Convertible
This Camaro originally came in for paint correction and while the interior was nice, it wasn't what I would call detailed and it was going to be shame to send the car out of the garage with a full exterior detail but leave the inside hurting. So I spoke with the owner and he agreed the interior could use a sprucing over so I jumped on this before doing the paint correction.
Here's how the Camaro looked when it first arrived.
How to Detail a car interior
First things first, I removed the floor mats and any personal items.
Next I moved the seats all the way forward and then blew everything under the seats forward using the Tornador Air Blow Out Gun Black.
Then I used the Tornador Velocity Vac to deep clean the back carpets.
After vacuuming the rear carpets I moved the seats all the way to the rear of the car and vacuumed the front. Then I blew under the seats a second time, this time blowing everything to the back. Moved the seats forward again and then re- acummued the rear again.
To do all this, I also wore the SCANGRIP I-Match II - if you do a lot of interior detailing, this is a must-have tool. And take my word for it, after you use all these tools to vacuum carpet - ITS CLEAN!
Blowing all the dirt and debris forward....
Vacuuming the rear....
Here's my tools of choice for getting interior carpet clean....
What is it?
What does it do?
When do I use it?
My comments....
