Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to use a hand applied abrasive polish or paint cleaner by hand
When working on clear coats by hand to actually "remove" defects, technique is just as important as your choice of product and pad, (pad = application material).
So do a Test Spot first.
Also, read the manufactures directions and follow them as the above is just a general guideline. The manufacture always knows their products best.
Paint Cleaners at Autogeek.net
Pinnacle Paintwork Cleansing Lotion
Wolfgang Paintwork Polish Enhancer
3M Scratch Remover
Dodo Juice Lime Prime Lite Cleaner Glaze
Dodo Juice Lime Prime Pre-Wax Cleanser Polish
Duragloss PreCleaner
1Z Einszett Paint Polish
Four Star Ultimate PreWax Cleanser
Griot's Garage Fine Hand Polish
Liquid Glass Pre-Cleaner
Meguiars SCRATCH X 2.0
Meguiars SwirlX Swirl Remover
Mothers California Gold Pre-Wax Cleaner
Mothers California Gold Scratch Remover
P21S Gloss Enhancing Paintwork Cleanser
Poorboy's World Professional Polish
SONAX Premium Class Paint Cleaner
SONAX Paint Cleaner
- Always work clean
- Use a clean, soft foam applicator pad, I really like these,
CCS Red Wax/Sealant Applicator Pads 2 Pack
Because they are fairly thick so the spread out the pressure of your fingers better than thinner versions.
(I like thinner versions for applying finishing waxes and sealants because then I'm not pushing hard so don't need the thickness).
- Work on a cool surface in the shade
- Work a small area at a time, about 8" to 10" squarish or so...
- Use an "ample" amount of product, don't under-use and don't overuse to the point that you hyper-lubricate the surface but use enough to keep the surface lubricated throughout the process. I would use a teaspoon to a tablespoon of product, usually a tablespoon's amount to start with because your pad is dry when you start and some of the product is going to go into the pad, and after breaking in your pad then cut down to about a teaspoon's amount of product.
- Hold your hand flat to the pad, not vertical, the idea is to not put pressure ONLY on your fingertips but over the face of your fingers to avoid Fingermarks
- Spread the product out over the area you're going to work
- Work the product for about a minute, don't work till the product is dry, but it should go from an opaque film to a clear film
- Wipe off before residue dries
- When you move on to a new area overlap a little into the previous area
3M Scratch Remover
SONAX Paint Cleaner
