The instructions are very vague and just describe applying it with a machine polisher and letting it dry to a haze and then buffing it off.
Is there anything more to it? As I understand, this is more of a filler than a correcter so using a polishing/finishing pad should be good, correct? I tried it out tonight on freshly clayed paint in a small section with my Griots polisher on speed 3 with light pressure and did 2-3 passes with a polishing pad. How do I know when it has dried to a haze? It looks "hazy" after being applied.
I'm following up with Poorboys Natty Blue paste wax. Would this be any different than applying a sealant. This is my first time using both of these products, and even using a paste wax at all.
Thank you.
Thank you.
