How to wash your car KISS style!
KISS stands for Keep it Simple Simon
Here in the forum world it's normal for people to take seemingly simple tasks that require a few steps to do a good job and turn the project into Rocket Science requiring multiple steps with sub-steps to boot.
Here's a simple way to wash a car, do a good job and get it clean and ready for detailing.
First things first - whose approach is better?
I go against the grain, that is I don't follow the advice handed down for decades by others on where to start when washing a car. Most of what I've ever read or been told by anyone that's anyone in the car detailing world when it comes to washing a car goes like this,
Traditional Recommend Approach to wash a car
Start at the top and work your way down
I totally disagree.
Start at the wheels, tires and wheel wells, and after these are washed and rinsed, then start at the top and work your way down.
Why?
Water spots
If you start at the top, wash and rinse all the body panels, you now have a wet car that needs to be dried off before the water dries and potentially leaves water spots on and even in the paint.
Water Filter Systems
If you have a water filter system like the CR Spotless Water Deionization System you don't have to worry about water spots. But if you don't have their system or something similar, then corrosive elements in the water could lead to nasty water spots on the paint and everything else unless you dry the water immediately.
Here's the deal though, if you do what most people do when using the traditional approach, that is leave the water on the car as you move onto washing and rinsing the wheels and tires next, (without drying the car), by the time you're done washing and rinsing the wheels and tires, (and doing a great job), the water will have already dried on some areas of the car potentially leaving water spots.
Dry the car before washing the wheels and tires
If you dry the car after washing it and then tackle the wheels and tires, it's pretty much impossible to not get the car wet again when washing and rinsing the wheels and tires so you end up drying the car a second time.
I'm not lazy, but I hate doing a job twice.
Here's my approach,
Wheels and tires first, then start at the top and work your way down.
Now lets put a little twist to the age-old traditional approach and instead of starting at the top and working your way down, lets start at the bottom and then move to the top.
Wash and rinse one wheel at a time. After washing and rinsing one wheel, move onto the next wheel and tire and occasionally re-rinse the previous wheel and tire because soap suds and wheel and tire cleaning chemicals have a way of re-appearing and pooling in voids due to gravity.
Continue washing, rinsing and re-rinsing until you've washed all four wheels and tires.
Now move to the top or highest point
Now that the wheels and tires are clean and rinsed, grab your wash mitt and gather some car wash suds and start at the roof and begin working your way down as you wash.
Divide the car you're washing up into sections or work panel by panel.
After washing a section or a panel, immediately rinse that section or panel to remove loosened dirt and other abrasive particles and to prevent any soap suds from drying on the car.
Continue this until you've worked your way from the top of the car to the bottom of the car washing the lowest body panels last as that's where the majority of the major dirt and road grime will accumulate.
By washing the lowest panels last, you prevent cross-contamination and by this I mean removing abrasive dirt particles off the lower portions of the car and moving them in your wash mitt to the higher portions of the car where you could possibly instill heavier swirls and scratches.
While you were washing and rinsing the car from top to bottom, you can occasionally give the wheels and tires a repeated blast of water to ensure any soapy water, wheel and tire cleaners, or even dirt particles that have flowed downward and pooled are continually rinsed clean.
At the very end of the process, give the car a final rinse and then you're ready to dry the car, wheels and tires and at no point will there ever have been the potential for water to dry on anything and thus no risk of water spotting on any portion of the car.
Plus, you won't have to repeat any steps.
That's how I wash a car.
But wait there's more...
If you're the type that REALLY wants to be careful so as to not induce any swirls and scratches into the paint, then here's a tweaked version of the above just for you.
Wash wheels and tires, then lowest body panels and then move to the top
A twist on my approach outlined above for the most anal retentive people would be to,
  1. Wash wheels and tires first
  2. Wash lowest, dirtiest body panels
  3. Change out water and wash mitt and start at the top and work your way down
By doing step #2 after washing and rinsing the wheels and tires, you've removed and reduced the potential to instill swirls and scratches into the upper body panels with gritty particles from the lower body panels BECAUSE you've removed the gritty dirt particles first.
This is an extra step that will take more time so use this technique if appeals to you and time is not an issue. It's also a good technique for washing a car with a flawless, show car finish to start with.
It is important however that after washing the lower panels that you do in fact change out the car wash solution in your bucket and switch to a clean, non-contaminated wash mitt.
Here's some pictures to show you how to wash a car starting with the wheels and tires first and then moving to the top and working your way down...
Tools Needed
GTechniq Gwash Car Wash Soap
CarPro Wool Wash Mitt
Detailer's Wheel Cleaner
CarPro's Iron X Iron Remover
Dual Bucket Wash System
Grit Guard Inserts
Short Handle Tire Brush
8" Boar's Hair Wheel Brush
Carrand Lug Nut Brush - Not pictured below
Optional
Wash & Rinse Bucket Labels
Quickly in a visually way, ensures you don't mix up your wash solution with your rinse solution
Here's my victim car, it's a 2004, low mileage Silver Metallic Honda Accord, probably the only one like it in the world.
Premium quality car wash soap, GTechniq GWash with a 100% Merino Wool Wash Mitt
Mixing two cupful of GWash with about 3+ gallons of water. The GWash Car Wash Soap has a pleasant cherry scent, it makes washing your car enjoyable.
After adding the car wash solution to my water I agitate the water with my fingers spread apart to create piles of rich suds....
Agitating... see the volume getting higher...
TTT or To The Top!
GWash car wash solution and clean rinse water are ready to go...
I'm washing in the early morning, before the sun gets too hot or the wind kicks up...
I start with the wheels and tires first...
I coated these wheels with Meguiar's Hot Rims Brake Dust Barrier back in January and it seems to be doing a good job of preventing brake dust and road grime from accumulating on the wheel.
These are the factory clear coated rims, likely very rare and hard to find. For this reason I'm going to use a 8" Boars Hair Wheel Brush to ensure I don't scratch the clear coat finish. The green tire brush is for the tires and the wheel wells.
Wheels and tires are agitated after spraying with the Detailer's Wheel Cleaner, which is non-acid and safe for both wheels and tires. After agitating the rims and tires, rinse well with water.
Tip from BobbyG
A while back there was a discussion on the best way to use Iron X there were three camps...
Camp 1 - Spray Iron X directly onto dry, dirty wheel.
Camp 2 - Wash wheel and tire, then rinse then spray Iron X onto clean, rinsed wheel.
Camp 3 - Wash wheel and tire, then rinse, then DRY off water and then spray on Iron X
I was in Camp 2 because I believed that by removing the road grime, (an oily coating), and the brake dust first, you enable the Iron X to do it's job more effectively to get the most bang for your buck.
The people in Camp 1 thought the Iron X was too costly to allow to possibly drip off the wheel with the excess water after washing and rinsing first.
Camp 3
BobbyG's technique was to simply wash the wheel and tire first, thus removing the oily road grime and brake dust but then pat the wheel dry using a clean utility towel so there would be no excess water to flush the freshly sprayed-on Iron X off the wheel and onto the ground where it's not doing anything for you.
I agree with BobbyG and wanted to share his tip and give him credit for an incredibly easy tweak to my technique so I can get the best performance out of Iron X and get the most bang for your Iron X bucks...
Now spray the Iron X onto the wheel to remove any Iron Particles (if any).
Everyone wants to see the red bleeding effect from the Iron particles being dissolved and in the process turning the water red. Actually, seeing no red water bleeding off the wheel is a good sign because it means your wheels are not contaminated.
If the wheels are contaminated and they have a clear layer of paint on them, this would mean iron particles had embedded onto and into the clear layer of paint causing corrosion to some degree.
No color, no corrosion = longer lasting finish on the wheel.
Continue washing and rinsing the wheels and tires until all four wheels and tires are washed clean and rinsed free from any residual chemicals and dirt.
Now it's time to wash the car starting at the top and then working your way down...
Washing the roof and sun roof first...
Moving quickly,
  • I washed all the horizontal surfaces and the side windows too and then rinsed these sections of paint.
  • Next I washed one side of the car tackling the vertical sides of the fenders and doors. After the sides, I hit the front grill and bumper then rinsed
  • Next I washed the vertical panels on the back of the car including the trunk lid, license plate and bumper.
  • Lastly, I washed the very lowest portions of the vertical panels.
As you're working around the car, you should be rinsing your mitt in the RINSE bucket to remove dirt particles gathered onto the wash mitt. When you do this suds build up in the RINSE bucket and it can be difficult to tell which bucket is the WASH solution bucket and which bucket is the RINSE bucket. The simple stickers shown on the buckets make it easy to quickly tell which bucket is which.
Next I gave the car a final rinse and wa la... a squeaky, clean Honda Accord.
As a good habit, I set my wash buckets on their side and rinse them and any dirt that has built up under the Grit Guard inserts out so the buckets will be clean and ready to use for the next detailing session.
And there you go... how to do a great job of washing your car, truck, suv intelligently, using the KISS method and at the same time avoiding water spots.
Great tips Mike for a basic hose type wash. Now we need a thread for us throughout the mid west that are being banned from washing cars at home. So break out some rinsless and or waterless products for us that haven't seen rain for 40-50 days. I was guilty of being dragged kicking and screaming to the waterless process. Looks like for a while the choice is out of our hands around here. So do you have any tips you would like to pass on to those like myself that are kind of high and dry as one might say ?
Great article Mike!
I actually washed my car today with Gwash and it suds up to much for such a small amount of product and cleans away dirt so effortlessly :dblthumb2:
I would love to see a waterless/rinsless too.
It's good to have a method to your madness... I also have a video on the above technique floating around YouTube that dates back to 2006, do a google search using these words,
How to Wash Your Car (ShowCar style!)
I've read a few articles about the Green Police, have seen any of these?
So break out some rinseless and or waterless products for us that haven't seen rain for 40-50 days. I was guilty of being dragged kicking and screaming to the waterless process. Looks like for a while the choice is out of our hands around here. So do you have any tips you would like to pass on to those like myself that are kind of high and dry as one might say ?
I have an older video on this but it's time to do a new one...
Thanks Mike for the quick reply. I know you have a plate full with the forum,videos,classes,tv shows,truck re-build and a new bride. As for the green police , they are starting their fines at over $125.00 w/no warning and the fine goes up sharply with repeated offenses. Two friends have been busted already. They claim they were turned in by neighbors. Local car washes are allowed to operate with a water reclaim system. I've done a few rinseless washes so far but no complaints yet.
ouch, that's frustrating to hear about the green gestapo.... of course this drought certainly is frustrating. here's hoping for a nice long rain-shower in the not-too-distant future!
I've given this some thought and think I may have some advice. Hybrid washing is more than just changing the order of events, but also using various techniques within the same regimen. One example would be for someone needing to clean wheels too dirty for a rinseless wash while still utilizing the rinseless wash for the body.
  • Wash the wheels, tires, fender wells traditionally or using a self serve bay
  • Then relocate to some shade or the comfort of a garage to rinseless wash the body
Another hybrid technique I use on large SUVs:
  • Wash the wheels, tires, and wells traditionally
  • Pressure rinse the wheel area, lower panels, crevaces, and bug areas
  • Relocate to shade or garage
  • Waterless wash the roof
  • Rinseless wash the more accessible panels.
Even if you can't break out the hose at home, you can:
  • Visit a self serve wash bay
  • Pressure rinse the paint to cool or go early
  • Apply a decon product to dwell on the paint while you wash the wheels
  • pressure and spot free rinse
  • now it's safe to use waterless or rinseless back at home.
I totally agree with Mike on doing wheels first regardless of regimen
Just curious as to how many miles are on that Accord, since you said it was low mileage. My mom has a 2001 Honda Accord that is just hitting 40,000 miles.
Mike,
Don't you change the water out when moving from wheels to paint? I always use separate buckets for the paint then i do for the wheels.
Also, i have yet to use ironX, but added it to my cart. In the description it says not to spray it on bare metal or calibers, but to cover these surfaces up. is this correct in the AG description because i never see (including your pictorial) anyone cover up the calibers?
I always enjoy reading your articles and looking at the enclosed pictures. Thanks for your time!
Last time you saw me and my wife when we came down for training, my wife was pregnant. We have a 1 year old running around now. im ready to have her start helping me clean wheels! lol
I did this just last week while on vacation. The hotel where are car was parked was home to some type of tree that was spewing out tree sap like nobody's business. I had just washed and waxed the car, so instead of letting the tree sap harden in the sun I took it to the local self serve car wash and $3.00 later all the tree sap was off the paint.
Just makes common sense to me. I'm confident all the authorities that state start at the top and work your way down and then wash the wheels and tires last probably aren't detailers or don't really understand how hard it is and what a paint in the rear it is to deal with water spots.
Don't know off hand but I'll check. Honda makes great cars. I'm a BBC guy through and through and pretty much only like trucks high enough they can't get door dings but it's hard to beat reliability and good gas mileage like you get from any Honda.
Mike,
I didn't and don't use a bucket for washing the wheels if I have a source of free flowing water.
  • Turn water on.
  • Spray wheel with water.
  • Spray wheel and tire with wheel and tire cleaner.
  • Agitate wheel and tire with appropriate brushes.
  • Rinse wheel and tire.
  • Pad wheel dry.
  • Spray wheel with Iron X.
  • Scrub wheel with appropriate brush.
  • Move on to next wheel and tire.
You can use a bucket with car wash soap and dip your brush into it and wash wheels and tires and of course I've done this in my live, it's an option but in the outline I wrote and in the procedures I used to get this Honda clean to apply Gtechniq products to last night in the studio I didn't.
Good question though...
In order to cover the calipers and do a job that would actually protect them it seems like you would have to remove the wheels.
I can't see people jacking up there cars, placing safety jack stands under them, removing the wheels and then covering their brake components.
I'm really not sure how a person could cover their rotors, (that's bare metal), or rotors effectively without removing the wheels. So I just spray the wheels down and any product that gets on the rotors and calipers gets hosed off. I guess it is what it is?
Thank you for the nice compliment. I've never studied photography but I've taken a lot of pictures and learned how to frame up the shot, crop out the fluff and tell a story with pictures to help get "ideas" across to the reader.
The goal is always to help others to duplicate same type of procedures.
Congratulations!
Been there, done that and raising your children will be the most important job you ever do...
That's about 3600 a year? Just detailed my Mom's '06 Accord, 18,600 miles, or 3100 a year :)
Here's my approach,
If you've never washed a car using the approach shared above, give it a try sometime, see if it works better for you or for the car. (It's all about the car by the way, not you).
And here's another tip...
Best darn tire cleaning brush I've ever used!
Yep, the Porter Cable with a Cyclo brush mounted to it instead of the backing plate! Takes ALL the elbow grease out of getting old, slimy tire dressings off, blooming, (the brown residue that builds-up when antiozonants meet ozone in the air), and deteriorated dead rubber.
