Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to wetsand a rattle can paint job?
I get e-mails, PM's and FB messages all the time with questions that are better asked and then answered on this forum for a host of reason. One reason is more eyeballs see the questions and answers so more people are helped versus one set of eyeballs in an e-mail, PM or FB message.
Hi Mike,
I've been searching the all over, on Auto Geek in particular, and am having a hard time finding the information I'm looking for.
I just painted my car with Dupli-color acrylic enamel clear coat, and on the horizontal surfaces I have what looks like tiger striping caused by misting off the nozzle.
I was planning on wet sanding at 2500 grit, then working my way finer with compounds.
A friend of mine advised against it saying that would be too aggressive for a simple enamel out of a rattle can, and that it would take too much off.
From what I've read so far some guys say to wait a month or longer before doing anything to it, others say a week, and some say 48 hrs.
Any information you can provide would be greatly appreciated
Great questions!
Let me see if I can shed some light....
The tiger stripes you're seeing from the rattle can paint job are pretty common for this type of paint application.
#2500 is actually pretty fine grit for a sandpaper or finishing paper. It used to be 10 years ago #2000 grit was considered fine grit and now we have, #2500, #3000, #4000 and #5000
You're friend is right in that any sanding on a rattle can paint job is probably aggressive unless you're laying down massive amounts of paint.
Keep in mind,
Sanding and buffing may remove or reduce the visible tiger stripes, you won't know until you try. Sand lightly and use a high quality compound to remove your sanding marks.
As for waiting time, check the back of the can or the website for the paint you're using and see if the company that makes the paint has their own recommendation as they know their product best.
When it comes to rattle can paint jobs, the paint tends to dry pretty fast and harden in a few days, so I would think that waiting 2-3 days would be fine. I'm not sure if rattle can paint would be any harder after a month than it will after 2 days.
Good luck with your project, by the way... what are you working on?
Hi Mike,
Great questions!
Keep in mind,
- Sanding removes paint.
- Compounding removes paint.
- Polishing removes a little paint.
