How, why & when to inspect your microfiber towels when detailing cars
I have a saying, goes like this...
The little things are the big things
Most detailers I know like the paint polishing aspect of car detailing. Like me, they love to take a diamond in the rough and turn it into a glistening gemstone. It's the challenge that attracts us and sense of accomplishment to save someone else's toy by giving it the quality finish it deserves. There's not much excitement when it comes to cleaning carpets or door jambs.
When most people think of machine polishing paint, the first things that come to mind are,
The tool - This would be your choice of polisher, be it a Makita, RUPES, FLEX, Griot's, Meguiar's, Porter Cable, etc.
The brand for compounds and polishes - some guys are loyal to Meguiar's, some guys are loyal to Menzerna etc.
The buffing pads - Lake Country, Buff & Shine, Meguiar's, Griot's and RUPES all make great pads
And while the above are VERY important to the success of a proper paint correction, it is the lowly microfiber towel that is the big thing. Think about it... what touches the paint the most? The polisher never touches the paint, it spins a pad against the paint but never actually touches the paint. The compounds and polishes touch the paint of course as do the pads... but after each step and even before you fire up your polisher, it is the microfiber towel that is all-present, always touching the paint.
Microfiber towels are used to,
  1. Wash cars for example when using rinseless and waterless washes
  2. Wipe of clay lube after claying the paint
  3. Wipe off clay lube after using any clay replacement like a Nanoksin towel
  4. Wipe off compound residue
  5. Wipe off polish residue
  6. Wipe of car waxes and synthetic sealants
  7. Wipe off paint strippers when chemically stripping the paint for a coating
  8. Giving the paint a final buff after applying a coating
  9. Spreading around and wiping off a spray detailer
  10. Spreading around and wiping off a spray wax or spray sealant
  11. Spreading around and wiping off a coating detailer or coating booster
And the above list is just paint-related job duties. The above list doesn't include CAREFULLY wiping off any product applied to matte paint or matte graphics and we all know that if you put a scratch into a matte surface that's a big no-no.
Gentle to scratch-sensitive paints
Microfiber towels are GREAT because by miniaturizing the nylon and polyester fibers, these fibers that in a large size could scratch the paint now become very gentle to the paint. This is extremely important because modern clearcoats paints, (and even single stage paints), are scratch-sensitive, this means they scratch easily. Because modern clearcoats tend to be harder than their older cousins single stage paints before the 1980s, the hardness factor makes them more difficult and time consuming to remove scratches out of so not putting scratches into them is vitally important.
Absorb and Adsorb
Microfiber towels both absorb and adsorb liquids and residues onto themselves.
aBsorb= Means to wick to the inside the fiber.
aDsorb = Means to wick onto the outside of the fiber​
Eco-friendly - great value
Can be washed and dried and used over and over again...
The down side of microfiber towels
The unique feature that makes microfiber towels gentle to paint is also their Achilles heel, that is the plush soft nap made from miniaturized strands of fibers are like traps for foreign debris and abrasive particles like dirt, dried plant leaves, sticks, rocks, brake dust, etc.
Abrasive particulates
When foreign debris lands on a microfiber towel it can bury into the nap and lodge itself firmly. If the foreign debris, often abrasive in form is rubbed against the paint - the risk is high that it's going to scratch the paint. If you've already compounded and polished a car's finish and then accidentally scratch the paint while wiping off a coat of wax - all your hard work will be undone. This is why it's important to not only have a method of storing both clean towels but also storing dirty towels until they go through the washing and drying process.
2 methods to inspect your towels
There are two ways to inspect your towels.
Visually - Look at the towel surface and if you see any type of abrasive particle or foreign substance, then pick it out.
Physically - Feel the face of both sides of the towel and if you feel something sharp, pointy or hard, then pick it out.
My friend Robert DiTerlizzi once showed me how he inspects towels before use and I though to myself, this is important, just as important as choosing the right compound or polish for the job. After he shared his practice of inspecting towels before using them I incorporated this practice into my own detailing system and also shared it with the online world with an article and also with the masses on our TV show as well as in all my detailing classes.
The Mike Phillips Twist
The only thing I changed about inspecting my towels before use is instead of inspecting towels on the fly, that is inspecting my towels as I use them, instead I pre-inspect them before starting the project or after they come out of the dryer.
While it takes a small chunk of time to pre-inspect our towels before staring the detailing project it saves time overall as your towels, because they are all pre-inspected, are ready to go as you need them enabling you to work faster through all the various steps of the process.
If you don't inspect your towels, I strongly recommend making this a new "best practice" for all your detailing projects. Wiping down a car with just a single contaminated towel is a time-killer plus it will require to compound and remove more paint in order to remove the scratch or scratches.
If you don't have a system in place for storing towels when not in use and after use, then get one. And after washing and drying your towels, take a small chunk of time to inspect them and then fold them before storing them in a clean, dirt and dust free location to keep them clean until needed.
Inspecting microfiber towels as they come out of the dry and before a detailing project
Clean towels on a clean workbench ready for Inspection
Visually look at the towels and look for abrasive particles or debris
If particles are discovered, pick them out...
Don't skip the edges of a microfiber towel...
If you can't pick the particle or debris out with your fingers then try to cut it out using some scissors
Next feel the towels and use your sense of touch to feel for abrasive particles or debris and if discovered, pick it out...
Pre-inspected towels - ready to be used or stored in a clean location for future use.
Culls - These towels did not pass inspection and will be relegated to non-paint polishing uses
When washing your microfiber towels, always use a dedicated microfiber towel clean to preserve the performance of the microfiber.
Get a laundry sorter and storage bin with a lid to store dirty towels until you're ready to wash and dry the towels.
This one has chambers to help keep your towels separated so you can wash and dry similar towels together.
Remember...
All you have to do is accidentally scratch paint one time with a contaminated microfiber towel for that statement to ring true and change how you treat your microfiber towels.
On Autogeek.com
BLACKFIRE Microfiber Cleaner & Restorer - 1 gallon
I'm glad I'm not the only one who squints their eyes at their towels and picks everything out. Time consuming, gives me a headache sometimes, but not a time goes by where I don't find a gremlin or two even right out of the wash.
Good write up.
Inspecting your towels before use or after they come out of the washer and dryer is just as important as any other process you do to the paint.
When I teach my classes I show and explain this multiple times over the course of the class to ingrain the practice into the brain of my students. It has to become a habit. Like breathing.
Good write up.
Thanks. Articles like this I always say
I pulled this one right out of thin air
The reason why is I wasn't in the garage to day to write this article or make this video. I was in the garage today to buff out the 2012 Yellow Jacket you see in the video. As a normal coruse of getting prepped for machine buffing I was inspecting my towels and I though,
"You know, I always want to capture this in a short, simple video because the content is important"
So I asked Elliot our social media guru to come out and take a video using his iPhone, which he did. Just kind of an on-the-fly type thing that if I don't do it right then and there it never gets done.
I posted this to DetailWorld and my FB page and the D101 FB page and so far good comments...
Thanks for taking the time to chime in...
More info...
Related articles on this topic,
Considerations for removing paint defects - the BIG PICTURE
Topical Defects vs Sub-Surface Defects - Living life on the edge of the razor blade
When to stop buffing - Or - How far should you go to remove swirls and scratches?
What it means to remove a scratch out of anything...
And avoiding swirls, scratches, water spots and oxidation
Things you need to wash a ceramic coated car by Mike Phillips
When it comes down to maintaining a scratch and swirl free finish - it all comes down to how you touch the paint - Mike Phillips
How to safely wash a ceramic coated car by Mike Phillips - Traditional Hose & Bucket Approach
***Bump***
Can't stress enough how important this simple job is.
You can be the best detailer in the world but if you compound or polish paint to perfect and then wipe the paint with a microfiber towel that has one single abrasive particle lodged into the weave you will scratch the paint and UNDO all your hard work.
Do like the method I share above, get your towels out and inspect them all at once. Then you can work faster as you don't need to inspect each towel before wiping.
Once you do this a few times it will become a habit and you will be thankful and you will also enjoy the feeling of confidence you get each time you go to wipe your car's paint.
So important.
Share with a friend too...
Great advice. You shared this tip during a video a while back and it was such an easy thing to do. I go as far as putting my higher quality towels in ziplock bags. I then store them in a dedicated microfiber only clear tote.
I just bought the new orange super plush wash mitt from Autogeek. One benefit of the long microfiber strands is the ability to cut out debris, especially tar that oftentimes gets stuck in my mitt. This mitt is my new favorite. You bet I inspect the mitt after laundering it:)
Last year my wife bought a food saver vacuum sealer. I was folding my microfibers and placed some super plush microfibers into a large bag. It was a total Autogeek moment watching the two or three towels shrink to a wrinkled, thin, package. Not practical for normal storage but for moving or winter storage it would be more appropriate. I did not see any negative impact on the towels that I vacuum sealed.
This is probably the most important or at least the most valuable article I've written for 2017
Especially when you consider it takes HOURS to correct and polish a car to perfection and only seconds to undo all your hard work with a single abrasive particle lodged into the nap of a microfiber towel.
Think about it...
On paint I only use light colored MF towels. When they come out of the dryer I put on a pair of reading glasses and turn on all the lights in the room, even if drapes are open on a sunny day then get to inspecting my towels.
After an extended session in my garage several years ago I discovered one of my clean grey MF towels had instilled scratches into freshly perfected paint. Front fascia of the G8 had to be redone. I found the culprit using my fingers and gently running them over the towels. I pulled a small sliver of plastic about 1.5 mm out of the towel.
Ouch! Not fun to scratch fresh paint $$$
Like I say...
Just did this last night. Couple loads of towels, all washed and dried, and then sat watching a hockey game and looked at every single towel. I give them a look over again before I use them, but doing them after washing and before folding to store makes sense to me.
My wife, on the other hand, laughs at me every time I carry the load out to the living room. But she doesn't seem to laugh when she sees how nice her car looks!
The Gold Plus are notorious (to me, at least) to pick up gunk. I figure they must be good towels - It's a real PIA to pick stuff out of those towels!
That's funny!
Yup. The flipside of the coin. :)
I've been using the Gold Plus Jr. 16"x16" towels since coming to Autogeek in 2009. This last year Andre and Bobby did some towel testing. When they were through they left some towels they tested in one of the dirty towel hampers on the garage. I washed them and then used them. Then I went and told Andre and Bobby I really like them. I think I also sent them an e-mail. I felt strongly enough about the towels that I wanted to make my opinion known in a strong manner.
Never heard anything from anyone.
A few months down the road these towels show up in inventory. I don't know if my feedback was a deciding factor or if it was just a normal addition to our offerings. But... I put an order in for a large quantity of these towels for my classes and now they are my favorite towel for wiping off compounds, polishes, cleaner/waxes and coatings.
The are edgeless - so no edge to worry about marring paint.
They have a FLAT tight weave - so less chance for particulates to bury into them - less contamination issues.
They are soft and plush - just normal characteristics we/I need for working on scratch-sensitive clearcoats.
I recently showcased them in two articles on how to maintain or wash ceramic coated cars. In my opinion - for whatever that is worth - these are excellent towels and perfect for washing or wiping ceramic coated cars. I'd highly recommend getting a 12-pack and testing the towels yourself and me for that matter.
Both articles show the towels and have links to them on the AG Store. They also cost less than the Gold Plush Jr. towels.
How to maintain a Coated Garage Queen by Mike Phillips
Here's the towels
12 Pack Forrest Green Edgeless Microfiber Polishing Cloths
Is everyone washing their brand new towels *before* using them for the first time? My towels look so good I’m tempted to just use them out of the bag but I always used to wash before using. I’m not sure if I should continue this practice.
I feel the same way.
