Just wanted to give a few details about adapting my PW to the MTM Hydro Professional Foam Lance. From the product description I knew the supplied adapters would not work, so I ordered a Bosch adapter from Autogeek. The Autogeek adapter had the correct bayonet end, but it would not go in far enough to rotate and lock. The rear end, that attaches to the gun, was a collar ~5/8" long and 0.935 od. To make it fit I turned off 0.100" for a length of ~0.425", leaving about a 3/16" shoulder at the end. This allowed the adapter to slide into the handle and rotate/lock. I then cut 2 opposing flats on the collar so I could use a wrench to tighten in on the gun. It works fine now.
My PW probably 10 years old. I understand the early one were made by Bosch, not sure if mine is one of those, mine said it was made in Italy (but not by whom).
I thought I would post this in case someone else has a problem adapting their Husky. Newer ones may not have this problem.
