Hybrid pads vs CCS pads
highroller
Hi all
I have question. All other things being equal how would you compare lake country's hybrid orange cutting pad vs CCS orange pad?
I got both but want to begin with one so want to know which one is more aggressive?
Purpose: to remove 2000 n 3000 grit sanding marks.
ps please rate these two pads on aggressiveness scale as I'm not very comfortable with microfiber pads or wool pads.
Thanks
  1. What are you working on?
  2. What are you trying to do?
  3. How much area did you or are you going to wetsand?
Have you read my article here,
Wetsanding - Fresh Paint vs Factory Paint
The Hydro-Tech cutting pad will be more aggressive than the CCS because it's closed cell while the CCS is open cell.
I explain the differences in my how-to book.
Paperback
:xyxthumbs:
Thanks for the help mike. Yes I have read your article and also other articles on wet sanding. N because of these articles I experimented with the paint in first place. Learned how to techniques and motion of sanding etc from your articles.
Well I tried to restore paint that got chipped off a little and a deep scratch.
So far I applied multiple coats of touch up paint and sanded with 2000 grit sand paper and finished with 3000.
The area done is very small, 1.5 by 1.5.
Next in plan of action is to use m105 with hybrid orange pad with DA followed by 205. Will try 2 attempts. Hopefully will remove sanding marks, if not then I'll revert to rotary and use a friend's rotary expertise.
