Hybrid Solutions Polish and Wax
Don M
Active member
Before & After on a Porsche
Torture Test
Going on the wife`s DD this weekend. Will be using the other TW products for upkeep .
Doing the K.I.S.S method keeping everything in the same line of products.
Sorry for dislike to early in morning and not finished with coffee, My apologies.
I'm very interested in this product. Like that they use some kind of new abrasive technology. What's also impresive on Brians test panel is that the guy who showcased this on the Arizona event. Said that if you polishing with a more coarse grade cutting pad you loose in the durability from it and gain the cutting ability. So if you do this with a fine polishing pad you get a longer and stronger durability from it. Which already with the more coarse pad Brian used had some pretty good chemical resistance at least. And with the 24h cure it's a primer for the HS Ceramic Spray Coating. Will be very interesting to see and hear about the real world durability from this combo. But if you would get around 9 months it would be very good. And if most DD would get over the year of longevity from it would be awesome. Then even if it's maybe not getting you the highest durability from when you top it up with it self it would be easy I think to get over the year mark. And you dial in the pad needed to be getting your paint look awesome again. To get that for around $30 total is awesome.
LOL, no worries, I saw you hit all three buttons and figured it was a caffeine deficiency or something like that :props:
My thoughts exactly.
Does a great job,BUT If you work this slow it will take to long to do a full car. If you were doing detailing for a living , you would not make much money working this slow.
