Hydro-tech pads for Klasse?
dietdewboy
I'm getting ready to pull the trigger on a GG polisher, 51/2" backing plate and some 7/8 thick Hydro-tech pads. After countless hours reading on here it seems that the hydro-tech pads are among the favorites. I want to use klasse AIO and sealant and I'm wondering which pads to use.
Since Klasse is not an aggressive compound I think you'll be pleased with the results you achieve with this pad.
Lake Country Hydro-Tech Tangerine
"The tangerine foam is made for light to moderate defect removal and polishing. It has the cutting power just below that of the Lake Country orange light cutting pad, and the tangerine pad leaves a finish like you'd achieve with a gray finishing pad"
I'd order 3 of this and 2 of the red for applying sealants and waxes.
Lake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads , hydrotech foam pads for water-based polishes, lake country foam pads, buffing pads
