Hyrdo2 Dilution Help?
CC268
Member
I want to pick up some Hyrdo2 for my wheels. I was going to get the 100ml bottle but I won't have enough to do a proper dilution of 4:1 with a 32 ounce spray bottle. What size spray bottle should I get? Car Pro says to dilute 4:1 which would be about 6.5 ounces of Hydro2 correct (if I use 32 ounc bottle). Are you guys typically buying the half liter?
100ml is equal to 3.38oz.
So 3.38oz x 4 = 13.52 oz
So fill up a 20oz or bigger bottle
with 13.5 oz of distilled water and pour in the full bottle of Hydro2 and shake it well before use
I first bought Hydro2 lite and still have some left. On my last order with AG,
I went and bought Hydro2 (100ml) but haven't used it yet.
You can use it further on even, 1:5 or 1:6 even,
so 100ml + 500ml water in any kind of sprayer bottle you have
Thanks guys I will start out with the 100ml bottle!
If you mix for a 32 oz bottle you'll have enough to last a long time, have you considered a smaller bottle? I use a 4oz bottle which is plenty for 3-5 washes. If you want a bigger bottle get the RTU Hydro Lite.
I just bought the 100ml bottle and a 32 oz spray bottle from car pro. I will just do a 5:1 ratio...100ml bottle and 500ml of water. If I want to utilize the full capacity of the 32 oz stay bottle I will buy the 500ml bottle of hyrdo2 later.
