I hate to ask this.....
DetailKitty
I'm having a moment here.
Should I clay/nanoskin BEFORE or AFTER I use IronX?
Sorry, brainfart I guess :doh:
I remember someone saying I did these 2 in the wrong order last time.
Thanks!
Yes ironX first then clay but if I were to do it again I would probably wash the car after ironX again to try and remove some of that smell.
You clay after you iron x the vehicle to ensure a deep decontamention and its all good we all have our moments were we forget something I guess its cause of all the autogeek information
There was a guy on this forum a while back who stated his nanoskin scrub pad got deformed after using Iron-X and wondered if it was from Iron-X. I haven't noticed that myself, but don't have extensive experience with using nanoskin after Iron-X.
Thanks gang!
As for the nano skin deforming.... I hope not, but we will find out I guess.
I have used nanoskin products after iron-x without any problems. As long as you thoroughly rinse after iron-x you should be fine. You can always do a test spot first.
Conversely, I tried using a nanoskin sponge over a spot that had tarminator on it, and that did not work out so well. It left black marring that I had to remove with clay. :doh:
