crg001
Member
- Oct 22, 2020
- 171
So I messed up. The other day I was closing a window in the garage, and the vibration of it somehow knocked over my Hi-Lift Jack (an off-road recovery jack, about 4-5 ft tall) I had stored in the corner. In slow motion, I watched in absolute horror as the tall heavy chunk of iron came crashing down on the front of my GLI. It made two deep gouges in the paint and left a small ding on the front passenger fender. Each scratch is about an inch or two long.
So, before I resign to sending it off to the body shop I want to attempt a repair myself. It appears it went down to the primer, but doesn't look like it went all the way to the metal. It is deep, though, so I could be mistaken. Right now I'm looking at getting a touch up paint kit that has the base color and a clear coat topper. However, I've never used these before.
I'm prepared to do whatever I can to make it look as level as possible. I was thinking about the process below:
1. Wash car
2. Clay/Spot polish area (to remove CQuartz coating around the scratches)
3. Wipe with IPA or panel wipe
4. Apply base coat (VW Pure Grey LH7J touch up) using a toothpick or small paint brush
5. Level wet paint with plastic scraper blade
6. Wipe excess with acetone
7. Let dry, then repeat process with clear
At which point, I'll probably polish the whole car and put on a new coating. I'm assuming I'll have to let this touched up area cure for a week or two beforehand though. And am prepared to wet sand and compound the area after said time. Hoping that is not necessary as I don't want to introduce excess heat and damage the touched up area.
How does this process sound? I've seen the Dr. Color Chip writeups here, but it seems those kits are more biased for chip repair and not so much for deep scratches. Or, would that kit work for this type of damage? I've never done touch ups like this and as a detailer, I want to do the process as perfectly as I can myself. The ding in the fender I'm just going to report as damage done and don't really have any plans for it.
Any tips, suggestions, critiques, or beers poured out for my poor busted fender are welcomed.
BTW, the high lift jack is a little more secured now. I had let my brother borrow it and he put it away in a high position which left it top heavy. Me, being dumb, never checked or secured it. Painful lesson learned.
1. Wash car
