One other point that is OFTEN overlooked is the speed of your internet connection versus the max. throughput of the router. Here is an example:
Assume you have a Verizon FIOS connection @ 25/25. That is 25Mbps downstream or "receiving" throughput and 25Mbps upstream or "sending" throughput. I will go on record and say that a majority of routers sold in the retail stores are UNABLE to support many of these premium services. What this means is you pay for 25/25 and get realistically 15/8 because of the delays introduced by the router chosen. The primary root cause is typically the processor in the router simply cannot process this much traffic from the WAN port and do it's other job duties (i.e. - wireless and wired LAN traffic, filtering, etc...)
Now you may say, "but my router is Gigabit speed so it shouldn't be a problem"...... and you would be wrong. WAN speed is separate and distinct from LAN speed. There is only 1 processor in a retail OTC router.
You can check for yourself by going to Speedtest.net - The Global Broadband Speed Test. The home page has a huge button for you to perform a test. It is usually best to use a system connected to the router using a cable (rather than wireless) to get the most accurate reading of not only your ISP but the devices in your home that enable connectivity to the Internet.
