67Customs
- Jan 29, 2007
- 581
So here is the deal. I painted my friends hood on his GTI like so...
I used BASF base and clear. I mixed the paint like I always have for every car I have done. I have never had problems before.
However, for some reason, the paint on his hood seems to have cured REALLY soft. 2 nights ago, a cat got on his hood and scratched it pretty good. So, he called me and asked me if I could get them out. I agreed and he came over. Well, I have had problems with the hood in the past. When I painted it, a gnat flew into the last coat of clear.
So, after it dried, I wetsanded it out and brought out the roatary and wool pad with some compound and then finished it up with my PC and polish. But, some light vertical scratches remained runnign up the hood. We let it go at that.
So, yesterday, I started out with OP on a LC orange light cutting pad on my PC at 5. It worked for the most part. It got rid of the cat scratches, but it didn't tough the scratches that were already there.
I then moved to OC on a LC orange light cutting pad on PC at 5. This is where things went horribly wrong. After I worked the polish in for a long time and then wiped it off, it looked like I lightly rubbed a brillow pad on the hood. It looked similar to this...
I dunno what happened. I suppose the compound was to harsh for the clear???
So, I brought out the same polishes and pads I used to correct this...
I used a XMT #3 on a LC orange light cutting pad and then moved to on to XMT #1 on a LC white polishing pad on PC at 5. It really cleared the hood back up. But, it only got the hood about 80% swirl free. Under halogen, it still looked kinda bad. Not terrible, but not perfect either.
So, what should I do? What would be my best course of action? Apparently, stronger compounds and pads make things worse. I have NEVER had this much trouble on an car before I I detail cars as a profession.
Here is a list of things I have to work with...
Complete XMT line
Meguiar's #2 Fine Cut Cleaner
Meguiar's #3 Machine Glaze
Meguiar's #9 Swirl Remover 2.0
3M Heavy Duty Rubbing Compound
3M Microfinishing Compund
Optimum Polish, Compund and Hyper Compound
PC 7424
Craftsmen Rotary (Borken
Full range of 6.5" LC pads
Full range of 4" LC pds
wool pads
sandpaper
Apparently, using the OP with a slightly aggressive pad worked the best. It just didn't have enough cut. Do you think moving up to a LC yellow cutting pad and OP the working my way back down through the pads would be the best option? Would that have enough cut?
I dunno, I need more advice. Sure I could keep trying different things, but but this isn't my car. I can't just practice on his car. I need to get this fixed. I need to hear some opinions and maybe some experience on this type of work.
Everythign I have learned in my detailing career has been thrown out the window with this paint. Help.
Complete XMT line
PC 7424
wool pads
sandpaper
