DRamsey New member Joined Nov 16, 2009 Messages 97 Reaction score 0 Nov 24, 2013 #1 Mike, I'm thinking about buying a foam cannon. I don't have a pressure washer, I don't mind buying one. I just want some advice on what is the best set up. Which pressure washer and which foam cannon?
Bill1234 New member Joined Apr 22, 2012 Messages 2,647 Reaction score 0 Nov 24, 2013 #2 DRamsey, You do have the option to buy a foam gun. It is similar to a foam cannon, but you use a garden hose instead of a power washer
M Mike@DedicatedPerfection New member Joined Feb 26, 2011 Messages 12,365 Reaction score 0 Nov 25, 2013 #3 As Bill mentioned you can use one with a regular hose. But if you are after the thick shaving cream style of foam then you will need a pressure washer. An electric unit will be fine.
D drvnbysound New member Joined Jul 13, 2013 Messages 172 Reaction score 0 Nov 25, 2013 #4 I use one of the foam guns with a hose. I love the results I get, especially when using something like Detailer's Xtreme Foam.
