IGL Kenzo - Soap & Top Coat?
Billabongi
New Kenzo customer here, been searching for recommendations on soap and a top coat for Kenzo but haven’t found much.
1st how often should I be applying a top coat? Second I’ve been fond of Car Pro Products and still have some remaining Hydro2 and Reset. Are these ok to continue to use with Kenzo or are there better suited products for Kenzo.
Both Reset and hydro2 will work with any coating.
If you are looking for a top coat to stay within the IGL family then consider Premier
IGL Ecocoat Premier
I'm a authorized IGL coatings installer and Kenzo authorized installer.
Reset is fine to use. I use Meguiars Hyper wash.
I would not use hydro2 on it. Grab some IGL Enhancer for a quick detailer and to add a bit of protection. And IGL Premier is what you want for a booster. It's not needed all the time though.
Thank you both, sounds like I'll continue to use Reset but move to IGL Premier for a booster. My car is a DD (2-4 days a week) otherwise garage kept so I think an every 6 month topper should work with every 3-4 weeks washes.
