IK Foam Pro 12 schrader valve?
Coatingsarecrack
Anyone know the size (1/4, 3/8 npt)?
If not how I could measure it?
I am trying to hook up the bike pump but looked in box where I kept all the parts and looks like I didn’t get one.
Any help is appreciated as I emailed IK and no reply.
My IK12's are regular bicycle pump style and size. IIRC Schrader or “American-type valve” is 8mm (5⁄16 inch) in diameter.
Could anyone who owns a FP12 load a picture of one with schrader valve connection?
Also does anyone know where to order replacement felt pads?
[mention]Klasse Act [/mention] ?
See below. I must of erased half the writing on this one. And is why you didn't understand.
Also if you plan hooking up a rechargeable pump get these.Makes things a ton easier.
Don't try and order one CAC. Mine was separate in the little
Get them if your going to hook up the pump. Makes life a ton easier. bag. If you didn't get one, then order the one on Amazon for $111.00 by The Rag Company and you'll get it in a couple days. Send the other one back. Don't try to retro it is a special one and is not like anything you can order.Amazon.com
Also if you plan hooking up a rechargeable pump get these.Amazon.comMakes things a ton easier.
I have all that and have a foam pro12 already. Just didn’t come with the schrader valve that screws in to the foam pro 12. There’s a spot for it and should be one that screws in.
I know Buddy! Call Rag and tell them to see if they have any, if they were the 3rd party you bought it from on Amazon?
If not it will most likely be impossible to get support. I seriously doubt either would have stock anyway.
As for ordering one anywhere you can't! it has threads to screw in that hole and all schrader valves are way different! They go in from inside and go into a NON THREADED 5/16 hole. Then have a nut on outside that tightens it down.
The IK one is made especially for there sprayer and it screws in where you remove the silver cap. They should of had it PRE-Installed and given buyers an extra one. vs. the cap. who the hell buys a pro if they didn't plan on using it with a Schrader.
Anyway, RETURN IT! Just buy a new one from RAG and get the little bag out of box and send it back! This is the only way you'll get the right valve. I know you want to just grab one that goes in there but there is zero like that. I bought some that I retro fitted in my marolex axel foamer 7000 and one for the EPOCA in a 32mm so they were not to long. But again they go in from inside out. Sorry for the hassle.
Just a couple I found on the A….
Coatings - I’ve not seen one in person, so I wasn’t sure how the schrader valve is setup. But from what I’m reading, it sounds like the one you got came with a threaded in plug instead of the valve?
If that’s the case, you could take that threaded plug to your local mom-and-pop hardware store and have them help you match up the threads. I doubt they’d have the valve part, but you could at least identify what you’re trying to find online.
The big box hardware stores tend to have cards hanging on the shelves in their nut/bolt/hardware section that might do it, but it’s nice to have that one on one with someone who cares. :D
Duh….. was gonna lug the whole IK in…. You sir are a smart man!
I could only assume you have the one you just sent a picture of. Since that is the EXACT part I'm trying to say is only made for there sprayer. It isn't anything you can buy or make.
Why you don't want to just return it is your business.
I’ve had it for way to long 1-2 years. And that is part I’m missing.
Those were for sale on Amazon. Not exclusive to the IK. They are used on a lot of different things.
I just was hoping to find the right size/threading.
I’ve found several different ones with differnt threading.
IÂ’ve had it for way to long 1-2 years. And that is part IÂ’m missing.
IÂ’ve found several different ones with differnt threading.
It’s OK to buy one and return it,,, less the little bag CACIm the MAN
That’s one way to look at it. Another way to look at it would be that’s a little sheisty to put a company through selling, shipping, and returning something just so you can get what you want…
And I was sticking up for you! Now I get it.
But how many time have you been put through having the shoe on the other foot??? I don't feel bad for all the $$$ I give Amazon every month. I would loose zero sleep! And yes as CAC said it perfect! "You sir are a smart man!"
Seems Dana thought I was being facetious but I was being serious. My thought was to just carry the whole IK in…. Yours is a way better idea
I'm pretty sure it's 1/8" threads. The cap on the IK website is 1/8 and the part # is 1/8 CAP WITH JOINT 8.26.76.303
Only thing different is the IK one has a rubber ring. But if you use the Teflon tape it should be fine.
