crg001
Member
- Oct 22, 2020
- 171
I'm polishing a '63 Continental this weekend - could use some tips! [first post]
Hi Mike and everyone on AGO!
Long time lurker on these forums, first time poster. I've been learning a ton from reading articles and forum posts and have been putting them to what I believe are really excellent results. I've been doing more and more of other people's vehicles and I feel I'm really getting great results polishing using a DA. However, single stage paint is still new to me and one of my friends is trusting me to polish his 1963 Lincoln Continental.
This car has definitely been repainted at some point in it's life with a single stage, and it's not the best quality respray. My friend believes it was done some time in the '90s. Another friend did a test spot on the trunk to see what results they could get using a 15mm DA and foam pads with (a non AG) polish and compound. Here's some pics of the vehicle and the aforementioned test panel. The results they got on the trunk is what he would like to see over the entire vehicle, and I believe I can do that or better.
View attachment 72712 View attachment 72713
View attachment 72714 View attachment 72715
Products I will be using are a Griot's G9, and my assortment of pads include 5+ each of B&S Uro-Fiber and yellow Uro-Tec, orange and yellow Griot's Boss, and green B&S flat pads. My polishes I plan to use are 3D ACA 500 with Uro Fiber or orange pads for the initial cut and then finish with 3D Speed (and top with 3D Express Wax) on the green or yellow pads, but first I will perform my own test spots. I also have Griot's Correcting Cream and 3D ACA 520 if the ACA 500 is too aggressive. I realize I could just one-step it with Speed, and I will try a test spot doing so, but my expectation is that it will not cut through the oxidation and imperfections well enough, as there are some deeper scratches and swirls in the paint.
My plan is to waterless wash it then clay before beginning.
I have some concerns about the paint quality around some spots so I plan to tape off the rough areas with delicate painter's tape and avoid them. See pics below.
View attachment 72716 View attachment 72717
There's also a small bubble on the hood that feels hard to the touch. I'm not sure if this is a thick glob of overspray paint or an actual air bubble underneath the paint and I'm not sure what to do about that. It crossed my mind to sand it down but I'd prefer not to overly abrade this paint.
I've read the articles about doing a Meguiar's #7 restoration on old single stage paints including this one using 3D AAT products,
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
How to restore a Barn Find - 1969 Ford Thunderbird - #7 Rub Out + FLEX = 3D products)
But time with the vehicle will be limited and this resprayed paint appears to be very thick.
Should I be concerned about starting with 3D ACA 500 compound and microfiber or orange pad without doing a #7 wipe down initially? Would it be worth the time to wipe on some #7 over the entire vehicle and then immediately wipe it off, and begin the correction process?
I'm a little nervous about this one, but I've never been so excited to polish a car before!
Thanks!
-Colin
Thanks!
-Colin
