I have seen quite a few threads in the past few months where people are using Colli 845IW as a topper.
I have always felt that due to the high chemical content (solvents?) that 845IW would remove much (most) of what it is being applied over.
I know I will not use it as a topper and I am hoping to get some opinions from those of you that have a good deal of experience with 845IW to potentially assist others from reducing their objective when they use 845IW as a topper...
Let's talk.....
I usually don't layer Colly 845 over
sealants....
Never over other brands of
carnuba waxes.
The solvent content ( be it the carrier system or not) does make me wary of there being negative, adverse effects on a sealant/wax (LSPs) being used as a "base coat" for this
layering application.
Material Safety Data Sheet
OSHA's Hazard Communication Standard,
consulted for specific requirements.
IDENTITY (As Used on Label and List)
#845 Insulator Wax
Section I
Manufacturer's Name
The Collinite Corporation
Address (Number, Street, City, State, and ZIP Code)
Utica, New York 13502
Signature of Preparer (optional)
Section II - Hazard Ingredients/Identity Information
Hazardous Components (Specific Chemical Identity;
Common Name(s))
Distillates, petroleum, hydrotreated light Unavailable 200 ppm* Unavailable
(CAS 64742-47-8 )
*A TLV has not been established for this product.
Section III - Physical/Chemical Characteristics
Boiling Point
Solvent: 360-415 °F
Mixture: 194-266 °F
Solubility in Water
None
Appearance & Odor
Yellow viscous liquid, pungent odor
Section IV - Fire and Explosion Hazard Data
Flash Point (Method Used): 140 °F 60 °C Tag closed cup
NFPA Class IIIA Combustible Liquid
Extinguishing Media: Foam, Dry Chemical, CO2, Water fog or spray.
Special Fire Fighting Procedures: Use air-supplied breathing equipment for enclosed areas. Cool exposed
containers with water spray. Avoid breathing vapor.
Auto-Ignition Temperature: 453 °F 233 °C
Unusual Fire and Explosion Hazards: Do not mix or store with strong oxidants like liquid chlorine or
concentrated oxygen. Combustible liquid.
Section V - Reactivity Data
Stability
Stable
May be used to comply with
29 CFR 1910.1200. Standard must be
Unstable Conditions to Avoid
X Fires, high temperatures
Specific Gravity (H2O = 1)
0.82
Vapor Density (AIR = 1)
Solvent: 5.3
Reactivity in Water
None
U.S. Department of Labor
Occupational Safety and Health Administration
(Non-Mandatory Form)
Form Approved
OMB No. 1218-0072
Note: Blank spaces are not permitted. If any item is not
applicable, or no information is available, the space must be
marked to indicate that.
Emergency Telephone Number
315-732-2282
Telephone Number for Information
315-732-2282
Date Prepared: 3-18-2011
OSHA PEL ACGIH TLV
Flammable Limits
Vapor Pressure (mmHg)
Solvent 24.3 @100.4 °F
Melting Point
Does not apply
Other Limits
Recommended %(optional)
LEL
1.1%
UEL
6.0%
But...
4. Can Collinite Last Step Products (LSP’s) be used in conjunction with an alternative brand
sealant?
Between producing, pouring and shipping, we’ve yet to conduct testing with all the sealants out there (too lengthy to list),
so this practice cannot be formally recommended. However,
sealant + Collinite LSP layering is a common method among Collinite aficionados. Call us with specific questions or check out reliable online forums with inquiries.
To sum it up:
Some folks do....and Some folks don't!
