Input pads Rotary
TREMEK
Hi Guys My firs post What a great Forum i have been reading for the last 4 nights :)
What Do you guys think of my Selection for my rotary. I plan to get a DA later and have allways used a rotary but im in need for some new pads.
Meguiars Mirror Glaze #105 Ultra-Cut Compound 8 oz. New D.A. Version [remove]
$10.99
Meguiars Mirror Glaze #205 Ultra Finishing Polish 8 oz. [remove]
$8.99
Meguiars Solo Easy Buff W66 Rotary Backing Plate 6 Inch [remove]
$23.99
Meguiars Soft Buff 6.5 Inch Foam Pads 6 Pack - Your Choice! [remove]
Pad 1: Yellow
Pad 2: Yellow
Expand options
$69.99
Meguiars Double Sided 100% Wool Cutting Pad [remove]
$24.99
Double-Sided Pad Rotary Adapter [remove]
$9.99
Total: $148.94
Checkout
Just clicked on this thread to find out your questions but also that this is your first post so...
Welcome to Autogeek Online! :welcome:
I've been offline most of the day working on a project or I try to get to these types of questions as soon as possible...
Your pad selection is perfectly fine. The double sided wool cutting pad is a great pad in my opinion and I've used it a lot since it was introduced.
The 6.5" pads work great on rotary buffers as do the Meguiar's 7" Softbuff pads and any of the Lake Country pads.
When it comes to buffing pads you can never have to many...
The rest of your selection looks fine also... I would recommend getting a Spur for keeping your wool pads clean, works much better than a screwdriver and it's safer too...
Lake Country Wool Pad Spur
Foam Pad Conditioning Brush
What are you working on?
Thanks for the replay Mike. I work on many different cars. Mostly removing swirls from older cars.
this is just my opinion(i use a rotary) get the m105/205 for sure, the pads get the lake country ones(cheaper meaning you can get more pads for same price) not that the meguiars ones are bad, which they are not. i personally use the 5.5" flat pads and love em. get a flexible backing plate, dont make the mistake i did and think the yellow lake country one would be a flexible backing plate(it is to some degree but only the outer 1/2" of the backing plate) go with the flexi-foam one.what i would do is get a 6 pack containing 2 orange 2 white 2 black then get a 2 3/4" backing plate and some 4" pads also. good luck in figuring out what pads to use, hope they work out good for you.
Thanks Guys i just ordered it all. I went with all recommendations :)
My local Prices and stock are not very good and you can never have to many pads..
autogeek_2186_133006671
Meguiars Solo Easy Buff W66 Rotary Backing Plate 6 Inch $23.99
1 Yes $23.99
autogeek_2181_27717301
  • Pad 1 : Yellow
  • Pad 2 : Yellow
  • Pad 3 : Yellow
  • Pad 4 : Beige
  • Pad 5 : Burgundy
  • Pad 6 : Burgundy
$69.99 1 Yes $69.99
autogeek_2182_76275794
Meguiars Double Sided 100% Wool Cutting Pad $24.99 1 Yes $24.99
autogeek_2183_53555178
Double-Sided Pad Rotary Adapter $9.99 1 Yes $9.99
autogeek_2183_59775863
Lake Country 5 1/2 Inch Flat Pads 6 Pack - Your Choice!
  • Pad 1 : Yellow
  • Pad 2 : Yellow
  • Pad 3 : White
  • Pad 4 : White
  • Pad 5 : White
  • Pad 6 : Black
$34.99 1 Yes $34.99
autogeek_2184_30900629
Flex-Foam HD Rotary Backing Plate $19.99 1 Yes $19.99
autogeek_2184_33892206
Meguiars Mirror Glaze #105 Ultra-Cut Compound 32 oz. New D.A. Version $25.99 1 Yes $25.99
autogeek_2183_62211637
Meguiars Mirror Glaze #205 Ultra Finishing Polish 32 oz. $27.99 1 Yes $27.99 Subtotal: $237.92 Shipping: $23.99 Tax: $0.00 15% savings: -$35.69 Total: $226.22
