Interested in the Pinnacle GlassWork Windshield Washer Booster
IID
Im looking to order this new Pinnacle Item:
autogeek_2243_18564365
But wanted to see if it plays nice with other windshield coatings (GTechniq G1,G5,ect...)?
so far i love it! currently windshield is sealed with blackfire crystal seal. it does not interfer with it in any way. my current fluid is rain-x.
That's what I was hoping....Thank You.
I was also looking at this new Pinnacle item as well:
autogeek_2239_6496435
Again,I was hoping that the "water repelling" ingredient's were still compatible with the other windshield coatings?
Nick if you have a chance to read this,can you please help clarify?
how long does a bottle last?
Considering 1 ounce treats a whopping 1 gallon of windshield washer fluid, it should last quite a long time. :dblthumb2:
Chris,
Pinnacle GlassWork Windshield Washer Booster will not interfere with the protective and/or hydrophobic properties of glass coatings/sealants. :)
Chris,
Thank you for replying Nick,order placed :)
Just to note...
The biggest enemy to a coating applied to a glass windshield is the wipers. The rubber wipers will tend to wear any coating off glass over the path of travel for the wipe blades.
So it's a good practice to plan on refreshing the coating on windshields on a regular basis if you're using your wipers a lot.
The Pinnacle Crystal Clear Glass Cleaner works really well, no streaks, easy wipe off and clear glass.
What is the anti-freeze for this product, I have to buy special wiper fluid (canadian -40 winter driving) so that is doesn't freeze.
I do not see anything on the web write up for it
It's not going to affect the freezing temperature of your existing anti-freeze. :dblthumb2:
to clairfy, i am adding it to rain -x winter washer fluid. my glass is not coated with rain-x. i wanted to add, after two weeks of winter driving, the pinnical booster makes a noticable difference!
today, i saw a washer fluid concentrate(Carplan UK). its warning reads. make sure fluid does not come into contact with paint. wonder if it means the concentrated or diluted fluid.....
