Interesting how everyone has different detailing ideas that they swear by. Some of the ones that I have observed -
Flat pads are better than dimple pads.
Waffle pads run cooler than flat pads which makes them better.
Slow arm motion is better when running a da polisher.
Fast arm motion is better when running a da polisher.
Microfiber pads run too hot and shouldn't be used.
Wool pads should only be used on a rotary.
Iron remover isn't needed if you clay the vehicle.
A da polisher still does a lot of work if the pad stall out.
If the pad stall out, then the machine just vibrates and isn't really doing anything.
What are some of the ones that you have heard?
