I wouldn't use any APC - it will probably make it worse.
The first thing I try is some simple water and light soap solution, even like some liquid hand soap and gently wipe to remove any finger oils using a clean, soft microfiber towel.
I'm sure others have good ideas too...
I've had really good luck on buttons and switchgear with ONR at normal rinseless wash ratio.
Thanks Mike! What are your thoughts on the ceramic coating to prevent it from getting worse.
The material is plastic and is already clean. It looks like the plastic is wearing out or breaking down. I always use a sun shade too!
