Introducing: 8 New Marine 31 Products!
Nick McKees37
McKee's 37 Product Support
Myself, Mike Phillips and the rest of the crew at PBMG have been hard at work the last few months developing a handful of new Marine 31 products. We're very excited to announce the addition of eight (8!) new products to the Marine 31 line. From the best fabric protectant money can buy to what is arguably the best liquid metal polish, these new products will surely impress you with their performance and ease of use. Each product is on sale for a very limited time!
Marine 31 T-Top Fabric Protectant with SunBlock
Marine 31 T-Top Fabric Protectant with SunBlock provides the best UV protection for all exterior and interior marine fabric surfaces including old and new bimini tops. Formulated using SunBlock technology – a fusion of Marine 31’s proprietary UV absorbers and advanced Ciba Tinuvin UV Blockers – treated surfaces will retain their color and texture while repelling dirt, dust, oil, grease, acid rain, salt, insects and bird droppings. Regularly treated surfaces will resist UV-induced fading, cracking and discoloring. This CFC-free formula meets California’s strict air quality standards.
Marine 31 Vinyl Protectant with SunBlock
Marine 31 Vinyl Protectant with SunBlock provides the best UV protection for all exterior and interior marine vinyl surfaces including bimini tops and seat cushions. Formulated using SunBlock technology – a fusion of Marine 31’s proprietary UV absorbers and advanced Ciba Tinuvin UV Blockers – treated surfaces will retain their color and texture while repelling dirt, dust, body oils and grease. This silicone-free formula ensures no surface is left slippery or sticky.
Marine 31 Fabric & Vinyl Cleaner
Marine 31 Fabric & Vinyl Cleaner is a concentrated marine cleaner that gently removes ground-in dirt, soiling, staining and light mildew from all marine fabric and vinyl surfaces. Marine 31 Fabric & Vinyl Cleaner features an environmentally-friendly formula that is non-toxic and biodegradable. Marine 31 Fabric & Vinyl Cleaner can safely be used to clean bimini tops, marine cushions, inflatable boats, seats, boat covers, sail covers and deck awnings.
Marine 31 Stainless Steel Liquid Polish
Marine 31 Stainless Steel Liquid Polish is the perfect solution to dull, oxidized, tarnished metal surfaces on your boat. This medium-cut polish is designed to restore the shine and luster to uncoated aluminum, stainless steel and chrome with very little effort. Marine 31 Stainless Steel Liquid Polish creates a highly reflective finish that can be seen from a distance. Marine 31 Stainless Steel Liquid Polish is arguably the best boat metal polish available!
Marine 31 Stainless Steel Liquid Sealant
Marine 31 Stainless Steel Liquid Sealant is a durable, acrylic based boat metal sealant that seals and protects stainless steel, aluminum and chrome surfaces. Treated surfaces will be well-protected against UV rays, salt degradation, bird droppings and other common contaminants that plague a boat’s metal surfaces from every day use. Designed to be applied to surfaces that are free of oxidation and rust, Marine 31 Stainless Steel Liquid Sealant creates a highly reflective, protective coating that lasts up to 6 months!
Marine 31 Spray Polishing Pad Cleaner
Marine 31 Spray Polishing Pad Cleaner is a fast-acting cleaner that quickly and effortlessly removes caked-on compound, polish and wax residue from all buffing pad types. Wool, foam and microfiber pads will look and feel new after each cleaning. Marine 31 Spray Polishing Pad Cleaner features a low-foaming, easy-rinse formula that ensures no unwanted residue is left in the pad. Clean your pads with Marine 31 Spray Polishing Pad Cleaner so you can maximize your investment!
Marine 31 Spray Polishing Pad Conditioner
Marine 31 Spray Polishing Pad Conditioner creates a smoother buffing experience by providing additional lubrication for your compound or polish. Marine 31 Spray Polishing Pad Conditioner is comprised of a unique blend of wetting agents that prevent compounds and polishes from caking up on the pad or from drying out while buffing. Marine 31 Spray Polishing Pad Conditioner is beneficial on foam, wool and microfiber pads. Application is as simple as spraying directly onto your buffing pad before adding compound or polish!
Marine 31 Polishing Pad Cleaner 16 oz.
Marine 31 Polishing Pad Cleaner is a concentrated citrus-based degreaser that breaks up and releases stubborn compound and polish residue from buffing pads. Formulated as a low-foaming, easy-rinse detergent, Marine 31 Polishing Pad Cleaner is a must-have product for those who detail boats for a living or have a large collection of buffing pads. Marine 31 Polishing Pad Cleaner can safely be used to clean foam, wool and microfiber pads.
Marine 31 Waxes, Cleaners & Polishes
:righton:
Great stuff Nick !!!! The Marine 31 Fabric Protectant looks great. If these are as good as the other Marine 31 products I have tried then folks will not be disappointed.
Ill be trying the vinyl protectant with sunblock that's for sure!
Keep up the good work guys!
Sent from my futuristic Apple device while in my office doing nothing.
Is the pad cleaner any different than the DP powder?
I was wondering the same thing! About to place an order and would like to know ASAP!
Detailer's Polishing Pad Rejuvenator is already the best, so it was the obvious choice when we were thinking about adding a pad cleaning powder to the Marine 31 line. Same great product, just marketed differently (you won't see DP in a marine store). :dblthumb2:
I take it the Marine 31 pad cleaner would be safe to use for pads that are used on cars?
Absolutely.
Both new pad cleaners in the Marine 31 line are safe and effective for all pad types, regardless of their application.
