Introducing SIX *NEW* Marine 31 Products!
Nick McKees37
McKee's 37 Product Support
Introducing SIX all-new Marine 31 products! We've been hard at work developing, testing, and fine-tuning these products the last couple months, and we're proud to finally have them on sale!
Marine 31 Mildew Guard
Marine 31 Mildew Guard is the solution to a common problem that plagues all boaters – mold and mildew growth on vinyl surfaces. This high-tech vinyl sealant forms a clear coating that protects against UV rays, body oils, salt, and most importantly, stubborn mold and mildew. Treated surfaces will retain their flexibility while being well protected against the damaging effects of nature.
Marine 31 Non-Skid Clear Sealant with Carnauba
Marine 31 Non-Skid Clear Sealant with Carnauba is a specially formulated non-skid boat wax that is designed to provide durable protection on fiberglass and gel coat non-skid surfaces. Formulated to fill in the microscopic pits and pores of non-skid gel coat surfaces, this high-tech non-skid boat wax forms a durable barrier of protection that protects the surface against the damaging effects of sun, rain, salt water, and more! Spray and wipe application makes Marine 13 Non-Skid Clear Sealant with Carnauba the best boat wax for non-skid surfaces – we guarantee it!
Marine 31 Plastic Clear
Marine 31 Plastic Clear is an all-in-one plastic cleaner, polish and protectant for your boat’s clear and colored plastic surfaces. This aerosol-based foaming cleaner is safe for all clear and colored plastics including acrylics, lexan, eisenglass, Plexiglas, instrument panels, plastic windshields, and more! Marine 31 Plastic Care penetrates deep into the pores of the plastic, removing embedded dirt to restore optical clarity. Its anti-static finish repels dirt and dust, leaving treated surfaces clean and protected.
Marine 31 Skin-Soft Hand Cleaning Wipes
Marine 31 Skin-Soft Hand Cleaning Wipes eliminate 99.9% of disease-causing germs and bacteria from skin. Perfect when soap and water aren’t available, Marine 31 Skin-Soft Hand Cleaning Wipes gently remove grease and grime without drying out your skin. A single tub contains 70 towels, each of which is fortified with natural emollients and soothing oils to prevent chapping. Try to find a better way to clean, sanitize and moisture your hands while out on the open water!
Marine 31 Stainless Steel Cleaner & Polish
Marine 31 Stainless Steel Cleaner & Polish is a spray-on, wipe-off cleaner, polish and protectant for stainless steel and chrome surfaces. Marine 31 Stainless Steel Cleaner & Polish removes dirt, grime, finger prints and smudges from stainless steel and chrome surfaces with a quick spray and wipe. This aerosol-based cleaner imparts a protective coating that resists finger prints, water splatter and grease. Stainless steel and chrome surfaces that are regularly treated will remain clean, shiny and protected.
Marine 31 All-Surface Citrus Cleaner
Marine 31 All-Surface Citrus Cleaner is an aerosol-based, foaming cleaner that removes built-up dirt, grime and soiling from virtually all marine surfaces. With a quick spray and wipe you can remove salt stains, grease, oil, grime and any other type of common stain that plagues a boat from every day use. Marine 31 All-Surface Citrus Cleaner has a built-in deodorizer that removes unpleasant odors from affected surfaces.
Be sure to check out the rest of the Marine 31 product line at Marine31.com
:dblthumb2:
