IPA before ceramic coating.
Luket
Will do a ipa wipe down on my sedan before coating .
1- what is your suggested alcohol to water mix.
2- Being a white car. Its hard to see if all products are removed.
How many towels and how many ounces of ipa mix would you thing one would go through. When doing a final wipe.
Thanks
Best off buying a pre-made product meant to be used. Home made IPA's aren't nearly as effective. If you're going to make your own it should be 1/3rd acetone and 2/3rds Windex. Again, better off just using something off the shelf if you're just a weekend project on personal vehicle(s) guy. 1-2 rags is all you need. Optimum Paint Prep is a good one. Doesn't contain any anti-static products thus works well.
I agree. If for nothing else, the purpose made products add a little lubrication too which helps prevent marring while doing the wipe down. I'm a repeat user of CarPro's Eraser, though I also liked Gyeon Prep. Unfortunately, I've not used similar products from other brands.
Thanks above.I have Geon prep. It seems so watery like one would have to use $20 worth just for one car.
It works really well and one bottle lasted me 3~4 mid-sized vehicles. It is thin, but all of those products are. You don't want them to be think and hard to wipe off. Spray on a good layer and it eats right though any polishing oils that might remain on the car after polish removal.
I use Gyeon Prep. It has been a great IPA for me. I am sure there are others that are just as good or better. But a Pre made Prep is the way to go IMO.
KEEP ON ROCKING!
Isn't acetone a little harsh for a wipe down? I know acetone and plastics don't mix.
You've probably used this mixture before or you wouldn't have post it. Just asking.
It's a very low dose of acetone and I only use it on painted surfaces. I do use it but not as much as in the past as I honestly just tend to buy off-the shelf gallons of Optimum's product now. It's a mix that Yvan Lacroix has touted for a long while and has proven very effective. I mention it for those that want to make their own.
Funnily enough, acetone and isopropanol are very similar chemically. Also, iso can be converted to acetone and acetone can be reduced to iso.
I’ve used Prep, Eraser and Black Fire panel prep.
Eraser seemed the best. Like the smell and wipe of it. BF and Prep tied for second. All seem to work well.
I try and use the panel wipe for the coating I'm using if available.
I have gallon jugs of Optimum, CarPro, and 3D panel wipes at my shop. At work we use CarPro Eraser for Ceramic Pro and Xpel coatings.
I love the way Eraser smells. The 3D panel wipe smells like straight up vinegar. The Optimum has a very light scent, but tends to remind me of Eraser in performance. Actually, they're all very similar.
^this. I'm a huge fan of staying in the family, especially with the coating product's own panel wipe.
What coating are you using?
I did my sons GMC Terrane yesterday . I clayed, Klasse AIO, then a spray ceramic. The car looks like a dark blue mirror. I didnot use anything after Klasse or befor the ceramic spray .
Eraser does smell great! BlackFire paint prep smells pretty good too.... cotton candy?
