IPA wipe down
Pimpmobile
I have never done a IPA wipe down as a surface prep so how much should rubbing alcohol be diluted 50/50 lower,higher?. When should I do wipe down before claying or after. My procedure is wash then dry clay polish if necessary. So which do I do first clay or ipa wipe down.
Good morning. I'm no expert but I use a 70/30 IPA. These folks here are awesome and will chime in. I use it after pushing before waxing. Hells remove oils so the wax or LSP will bond better with the paint. Hope that helps.
Sent from my SM-G935V using Autogeekonline mobile app
Should I clay bar before or after ipa wipe down
Here's my method.... Wash. Clay. Polish. IPA. Wax.
No real need to IPA before polishing, but you can if it helps you see how your correction is going.
as a surface prep...
Have you done "The Baggie Test"
to see if claying is actually needed?
Note:
If claying is needed...I always
polish afterwards.
What type of LSP are you going
to be applying---Wax, Sealant,
Coating?
I don't do IPA Wipe-downs (or use
any other surface prep products)
unless the LSP manufacturer specifically
recommends to do so.
Why take the chance on possibly
bogeying up the freshly cleaned
and polished paintwork?!?!
Note:
polish afterwards.
Coating?
To piggyback off of Bob..
Miscible and Immiscible - Wax and Paint Sealant Bonding
