Iron remover turned yellow in bottle after opening.
DanaDetailingPros
Active member
I called Adam’s and a guy assured me it was fine to use and it happens. Wanted your experience?
Amazon purchase by chance? I think I saw this on their forum once and same reply, they recommended to shake it up and use.
I'm 15mins from their HQ though and personally, for iron remover, I'd go and ask them to replace.
Sent from my SM-F936U1 using Tapatalk
I am going to call them then again. It defiantly was bought through them!
I found it - the general consensus was sunlight exposure but still good to use.
I have not concluded if there is a -shelf life- of Thioglycolic, the main ingredient .
I've used some Sonax FE that just wasn't effective any more - stored in temp controlled environment.
It's in a dark bottle so no #### on product color....
In other things like construction adhesives and what not, I am mindful to look at batch code dates, etc just to see
Theyy wrote back this:
Hello Brian,
As I'm sure whoever you spoke with on the phone told you, I would use either of those products with zero hesitation! Iron remover is very fickle when it comes to manufacturing the product with a consistent color, and anything from extremely high to extremely low temperature can also cause the color to be altered slightly. I can assure you that the product is perfectly fine, and that it will still be just as effective as any other bottles.
Thank you for contacting us and thank you for your business!
Hello Brian,
My gallon of NV Purge has done the same. It comes as a darkish blue but has shifted to an amber colour. It still functions the same. Having said that, my gallon of Gyeon Iron is still the same clear liquid it was when I opened the bottle.
