Iron x to strip gel coat?
bus3
Hello everyone I was wondering what you use to strip gel coat on boats? I have used iron x on vehicles but not sure if it’s safe for gel coat. Thank you.
Thank you.
The last 3 boats we've detailed here at Autogeek we have not chemically stripped using an iron remover.
I have chemically stripped single stage paint and what I saw is that because single stage paint is porous - the iron removers stained the paint. This staining can be removed as soon as you use a compound, polish or cleaner/wax.
My guess is the same thing will happen to gel-coat because like old school single stage paint - it's porous.
What are you working on?
What are you going to do to the gel-coat after washing?
Thanks Mike. I will be doing a single stage polish ( some areas may need more) and then coat with Crystal Serum light.
My guess is the polishing step will remove any staining, if there's any staining.
A chalky, severely oxidized gel-coat surface is MORE OPEN than a gel-coat surface that has been maintained and has a hard shine.
You could always test in a isolated section first and go from their based upon the results.
