iron x? wheel cleaner?
CowboyTruckn
I think I'm about to purchase a new/used set of wheels 1500 miles and I'm going to clean them up before I put them on the car.
Can iron x be used as strictly a wheel cleaner or I'd it more of a pure decon step. Either way I'm going to use iron x but if it will save me a step why not. Thanks
Used wheels will have, at the very least:
ferrous contaminates (hopefully not too sintered).
1. Wash them with your regular car wash shampoo. Rinse.
2. Follow this with the IronX. Rinse thoroughly.
3. Repeat step 1.
4. Inspect.
5. Use a dedicated wheel cleaning product that's safe for these type of wheels, if deemed necessary.
6. Seal both inner/outer barrels with your choice of
"wheel LSP".
I would use it as strictly a decon step. Mike Phillips has a great article on using Iron-X as a wheel decon. The biggest thing is making sure to dry the wheel after the initial cleaning, before the Iron-X. I believe Mike says it is a tip from BobbyG, so you know it's good!
Clean wheel with wheel cleaner or APC
Dry Wheel
Iron-X
Rinse
Clay, if needed
Seal or coat, and you're done!
Use ironX soap diluted in a bottle instead of ironX as a wheel cleaner.
Combining chemistry and economy, the best method with wheels will be:
1) Power hose without any product (removes anything loose - saves you wasting product to remove this)
2) Dedicated Wheel Cleaner (will get rid of some of the brake dust and much of the oily soiling - the latter can inhibit the effectiveness of bleeding cleaners)
3) Bleeding cleaner (use last, it means that your most expensive product is focused only on the stuff which simpler methods have failed to remove).
When you see someone spraying a bleeding product onto a wheel which has not had any pre-treatment, they either don't know what they are doing or they are doing it with their primary motivation being to see a massive bleed. In practice, all that bleeding is your product reacting with the brake dust. Once it bleeds, that product is used up, it can't react with anything else and there is more chance that you will exhaust the product which you have applied and thus require re-application. It is actually amazing how much will be removed simply with a water jet and how much more cost effective your clean can be by doing this.
Incidentally, with IX, apply dry or you won't get sufficient contact. Some of the other products are better designed for longer contact time.
