I've never tried it with either. I usually just wash normal then clay towel right behind the wash mitt. Give it a try and let us know how it does!That’s what I was worried about. He makes a big deal about the surfactants and lubricants in the DIY version.
Didn’t pick up any DIY because I have a lot of IronX sitting around. Probably won’t risk it. Paint on the Bronco appears very good so I’ll avoid correction if I can.I've never tried it with either. I usually just wash normal then clay towel right behind the wash mitt. Give it a try and let us know how it does!
I’ll probably do a test spot to see if it’s even necessary. I usually don’t get much reaction at all to iron removers here. I’m pretty sure I’m not going to attempt what I asked about. I’ll probably try to use up a spray bottle of Dodo Juice clay lube I have (and have had for a long while) with my clay towel.I would think with CarPro having their own clay lube I wouldn’t. You could iron remove, snow foam then clay, then rinse.
