Is Anyone Using an Air Spray Gun to Apply Ceramic Coatings?
XJL
I'm mainly interested in using it to apply on wheels, grilles, and other hard to reach surfaces where an application pad just won't work. If you are using an air spray gun or air brush, could you please provide the name and model you have? Also, how you like using it.
Thanks so much!
Thanks! There are so many different kinds of air spray/air brush guns out there I'm just trying not to reinvent the wheel.
I do with DLux and tire coatings.
Harbor freight makes a small HVLP gun that works perfect and is cheap.
Not gonna use a high quality gun as the coatings may clog/ruin the gun.
Thank you! Do you use lacquer thinner to clean it out after use?
Have you considered using one of the spray-on coatings ? PBL Surface Coating is just one of several examples.
I'm interested in coating my plastic grille primarily, which is impossible to do with the standard applicator. I'd use Gyeon Trim or Gtechniq Permanent Trim Restorer. I haven't seen any spray on type coatings for plastics.
XJL. If you are looking for a super easy product, check this out.
Meguiars Plastic & Vinyl Coating, exterior trim coating, trim dressing, vinyl protectant
Already in an aerosol form. Looks great, super easy to use, It’s hydrophobic, any overspray cleans right off glass or paint. Only draw back is that it won’t last as long as a true coating like DLUX.
Just wanted to give you another option.
^^ this It's my go-to spray on. I've looked into an airbrush set up for coatings but the over-use of product makes it a bit pricey and clean up would be a pain. Results on wheels would be outstanding but at a cost though $ Trim wise though the above is what I use.
I've used similar products in the past but it just makes no sense for me keep reapplying it every few weeks. I've applied Gyeon Trim with a Q-tip to the front grille on one of my cars and it looks magnificent!
Just to chime in,
I don't have any experience with this technique but I think it's Anthony Orosco and Ron Harris, owners of Concours Auto Salon, LLC in San Antonio, Texas that pioneered and perfected this technique. At least with Optimum Polymer Technologies products. I remember Anthony showing me this technique while I was there for a GTG in 2010
GTG in San Antonio, Texas Thursday, October 14th
Ron Harris and Anthony Orosco
I'm pretty sure I remember Anthony demonstrating this technique on the passenger side front fender while I was there.
Anthony's sharing tips and techniques...
Car Detailing History
