aim4squirrels
Active member
- Nov 6, 2013
- 1,078
If a car is lightly soiled with a week's worth of dust/dirt accumulation, is foaming enough to remove it, given that I have access to a foam cannon and pressure washer to remove the soap and dirt accumulation?
Reason I ask is because I've been thinking about the old mantra of the less you touch the paint, the less likely you are to induce marring.
I have a Black vehicle, and I've always followed a foaming with a 2 bucket wash. I'm also paranoid about inducing more scratching/marring than is absolutely necessary. It made me wonder that if foaming is indeed enough, then perhaps running a wash mitt over it is actually excessive and might be overkill if there has been nothing more than a wind blown dirt accumulation in a week's time especially if the vehicle is coated (PBL diamond surface coated) which seems to repel dirt accumulation much better than a typical wax or sealant.
I'll admit I'm too much of a coward to experiment, but I wonder if there are some of you out there that might have experimented with this and can tell me your experiences with it good or bad.
After all, I won't live long enough to make every mistake on my own.
