A water dilutable degreaser will not be acidic, in order to dissolve grease, it has to be alkaline. If it isn't then marketing is involved! In actual practice, such degreasers are very similar to non acid wheel cleaners so quite safe on wheels. Only thing to check is whether the degreaser has caustic sodium hydroxide. If so, it could react with sensitive finishes (in fairness, many wheel cleaners have the same hazard).
An example of a caustic degreaser would be 1Z W99. The stuff is the most powerful I have used, but it has sodium hydroxide in it.
Hmm..so is this safe to use on wheels? I plan to try it out at 3:1 dilution to clean tires and wheels.
I was just wondering if it is okay to use a degreaser on any type of wheel. What do y'all think? Is it too acidic? Does it damage your wheel?Feed back please
Mike Phillips said:What I would do is look at your wheels, determine what it will cost you to replace them should the finish be destroyed, then weigh that against the cost of using a product specifically made for the finish on your wheel.
Just to note... a good rule of thumb is to use the least aggressive product to get the job done... using a degreasers to clean wheels is kind of overkill. Sure you can dilute it but there are reputable companies, with brands you recognize that have already invested a lot of time and money creating products specifically for cleaning wheels without causing harm.
A good wheel cleaner needs to,
- Dissolve oily road grime
- Release or dissolve brake dust
While a degreaser will do this it likely contains a lot of other grease and oil dissolving ingredients that are not going to be safe for all wheels. Maybe some wheels, but not all wheels.
I cover the topic of how to determine what you wheel is made from or coated with as these are two different factors and then how to safely clean them in my how-to book.
Mike Phillips’ The Complete Guide to a Show Car Shine Paperback Book
E-book
Thanks for the feedback Mike!! BUT what would you do then if you have like a small part time car wash business but you don't want to invest a lot of money on products that run out so quickly? Because wheel cleaner tend to run out quickly!!
Once again, thanks a lot for taking your time to read this post.
