I mean is it ''scientificaly'' possible to remove layer of metal to get a clean swirl-free metal?
It all depends on what "metal" it is you are talking about, in relation to what it can and cant be polished to.
If you are talking about raw metals, as in aluminum, steel, etc, then yes. It is pretty much just limited to the amount of metal you have. If you are talking about chrome, then not so much.
The reason I say this, is because chrome itself is not really a "metal". It is a plating on the metal. This means that the chrome has a limited depth or "thickness" which is normally NOT to thick at all. It is also very hard. When you take into consideration the risk you run when trying to polish it, and the probability of striking through the plating to the metal behind it, most of the times it is not worth it.
I dont recommend trying to "polish" chrome. If you are talking about a raw metal, then polish until you get the outcome you are looking for. Hopefully are you able to understand what I am saying here.
