never seen or used a yellow.Is it wider than white?I use a 2400psi Karcher and make it a rule to use the 15* tip (yellow) and to stay at least 20" from the surface. Any closer and you do chance blowing paint off; maybe not on a new car, but anything with older paint it's way too easy to do. I've seen it happen before!
Or just use a lower pressure electric, or a standard hose.
I bought a Brigg & straton 2500PSI washer
which works wonderful on my Sorento.
I use delicate tip.
•It appears to me that youis it safe to use pressure washer
to wash car?
Cuts so much time with wheels nasty mats and door jambs.A must to have in all aspects.This is why guys are spending 3 hrs to clean wheels.your saving 2 hours easily.personally I don't see the point of using a pressure washer. Just a waste of money unless you need one for some other reason.
45 minutes is to long.Replacing the soap bucket is time wasted and added labor.There is no comparison as far as quickness.Everyone believes in there way of doing things.If it works for you than that's all it matters.I cleaned wheels that had 7 years of brake dust on them in 45 minutes without a pressure washer. So I don't know why it would take 3 hours?
(Yes the car was never washed for 7 years the rims had clear coat failure on them too as a result of the neglect.)
I'm sure it would have been easier, but I don't really see the point in getting one for just wheels.
Sonax Full Effect + dwell, + brushes, + diablo gel, plus buckets with car soap. Get it all done. Repeat a second time, third time if needed. ! wheel is done in 10 minutes. Dump water, add more soap, and repeat. Each wheel gets a fresh new bucket of soap and water.![]()
Sonax Full Effect + dwell, + brushes, + diablo gel, plus buckets with car soap. Get it all done. Repeat a second time, third time if needed. ! wheel is done in 10 minutes. Dump water, add more soap, and repeat. Each wheel gets a fresh new bucket of soap and water.I'll probably add ONR into that mix in the future as I ordered some of that.
In the future, do not purchase diablo gel. Seems like a waste of money and using Meguires APC or Degreaser seems more effective!
