Is Meguiar's products contain silicon?
dhsv2
M85.M80.M105.M205
Are you asking about silicon (element, in its silicon dioxide form, also known as sand), or silicone (a synthetic compound made of siloxane molecules)?
Seeing as you have even confused me ;) I think he means #2
I do believe that all those products say, "body shop safe." Hence, no silicones.
That's assuming the OP is not referring to 'sand'.
Bill
@OP:
•Sounds to me that you are suggesting that
there are "good", as well as "bad" silicones?
•Do you want to know if Meguiar's uses any of
the "bad kinds" of silicone in any of its products?
Anyway...
{From Meguiar's spokespersons/chemists/formulators:}
"All the raw materials we use are completely safe, and will not damage the surface they are formulated to be used on. Any additional information regarding our formulas or ingredients we use is proprietary information and can not be shared".
And from a Mike Phillips article:
..."unless you're getting your car ready to be painted:
as in you're just about to push the car or drive the car
into a paint booth to have fresh paint sprayed onto it...
it really doesn't matter. Silicone is inert, it wont hurt anything".
Also from Mr. Phillips:
"In the big picture of life, sometimes you just have
to place your trust in the name on the bottle".
__________________________________________________
@OP:
Anyway...
Bob, just curious, how long does it take you on average to write a post in a thread at any given time?
He told me that a friend Meguiar used silicon material that cover the scratches
And told me that I can not use a product (SONAX ProfiLine Nano paint protect)
To after using alcohol to strip paint from Silicon
:laughing: That's what I was thinking!
OP, with respect, it sounds like you are being fed BS.
Almost all detailing products contain silicone in one form or other. None of the products you mentioned are designed to "fill" scratches. They all contain polishing oils and other carrier ingredients that can act as fillers, but that's not their intended purpose.
Just about any polish or compound has a slight ability to fill (i.e. it leaves a tiny bit of something behind), hence why some people like to do wipe downs with IPA / Eraser etc after polishing to remove polishing oils (potential fillers) and check the true condition of the paint.
I feel like the plane is flying, but nobody is in the cockpit.
OP, what are you trying to do??
I know there is silicone in many sealants including Menzerna's PowerLock. I doubt they would put in in a polish unless it was an all in one, so for for the products you asked for which are pure compounds and polishes, I really doubt you will find any Silicone in it.
I think the whole Mirror Glaze line is free of silicones that can cause body shop issues. They would have to be, since the line is targeted at body shops.
^^ This
Are you concerned about whether those products are body shop safe, or whether they fill in scratches?
Either way they're both a moot point IMO.
I think the OP might be asking if he needs to do an IPA wipe down to prep the surface for nano lack after polishing.
IIRC, Sonax has a cleaner product specifically designed for use before applying nano lack to remove any polishing oils/residue. There's a couple comments over here recommending a prep wipedown:
Sonax Nano Lack (paint) protect
